Thread: Testing CCs without testing FC
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Is there a quick way to test for CCs without going through the entire chlorine drop test?
    Or at least a way to use the drop test without testing for FC first?
    Thanks
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Re: Testing CCs without testing FC
    Nope. To measure CC with the FAS-DPD chlorine test, you must first measure the FC level. The only shortcut you can take is that you don't have to count the number of drops in the FC phase of the test (which doesn't really help).
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Ok. Thanks for the quick response
