Results 1 to 11 of 11
Thread: Brass and Chlorine
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Brass and Chlorine
    I was looking at adding some grommets to my solar cover (maybe brass)
    Is there a downside to this regarding chemical reactions with the chlorine?
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    30,107
    Re: Brass and Chlorine
    Chlorine will attack virtually any metal. Even stainless in the right concentration.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Yep, chlorine'll eat it.
    Apr 2010
    Buckeye, AZ 85326
    618
    I am pretty sure my pool light has brass conduit running to it. I thought the PB did it because brass stands up better to pool water?
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Cincinnati, OH
    424
    I'm thinking it might be alright in my situation, since the only time it would really be touching chlorine is when the cover is rolled onto the reel, otherwise the grommets would be up out of the water. Hrm.
    Eric
    Jun 2007
    New Jersey
    653
    Back in the day, brass hardware was commonly used in pool equipment. Before the plastic butterflys, brass bolts and wing-nuts held your attachments to your pole. Brass ball floats held up the the rubber vac hoses that could not float on their own. Of course, with no CYA, FC was normally 1-3ppm. I think they will hold up just fine.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    30,107
    I probably should've qualified what I said. In pool concentrations, I think brass will function just fine. It'll corrode very, very quickly but it will not be unusable. If you don't mind the look, I would use it.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    562
    It looks like my main drain cover has brass screws and I don't see any corrosion at all (?) Is there something like "marine grade" brass that maybe there are?
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    22,369
    There's a lot of brass and bronze used on boats and ships. Just saying!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    loop-loc cover anchors are brass they weather well, but they are just near the pool not in it
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2007
    San Rafael, CA USA
    12,082
    Brass is an alloy of copper and zinc. The rate of corrosion is higher when the percentage of zinc is higher. Keeping the zinc below 15% and adding a small amount (1%) of tin can make the brass more resistant to corrosion as described here.
