Results 1 to 12 of 12
Thread: Greenish Crystals in Pool
    Mar 2010
    Fresno, CA
    14
    I have a SWG and recently noticed some greensih salt crystals forming in one corner of the pool with some silt. Any idea what could be causing this? My Salt reading is also lower that it has been over the past months.
    35k / Hayward Swim Clear C4025 Cartridge Filter / Aqua Rite SWG / In ground / Pebble Tec
    30,419
    Re: Greenish Crystals in Pool
    My first reaction would be to clean them out and see if they reappear.
    Mar 2010
    Fresno, CA
    14
    I have and they came back. They are also in the pool skimmer net. It looks sort of like pool salt, but I can't imagine that the salt would be reforming.
    Ft Lauderdale, Florida
    1,455
    Do you have a heater or copper pipes?
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Mar 2010
    Fresno, CA
    14
    Quote Originally Posted by Poolsean
    No, I don't.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Can you post a picture of them?
    Feb 2008
    Denton, TX
    5,061
    Have you considered having a pool store run a test for the presence of metals in the water? I would specifically be interested to know if there is copper in there and if so, in what quantities.
    Can you post a set of test results as well?
    Butterfly's Avatar
    South Carolina
    10,045
    Have you added any copper based algaecides or anything that contains copper?
    A full set of test results would be helpful.
    You're done SLAMing when:
    Mar 2010
    Fresno, CA
    14
    Quote Originally Posted by Melt In The Sun
    Here are some pictures. It sort of looks like undissolved salt, but I can't imagine why that would be the case. I'm going to have Leslies run a test this weekend.
    1,455
    not sure what this is. Wind blown debris ending up in your pool? Sand from Paver stone deck? Did you use Bacquacil/bagunide based chemicals previously? Is it clumped together bacause it's wet or is it slimy?
    Mar 2010
    Fresno, CA
    14
    No.
    It's clumped together because it's wet. It's not slimy. I've also found this stuff in the skimmer net.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Are you close to the Gulf of Mexico?
    Ok, i am sorry, could not resist.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
