Thread: lid on pump basket
    lid on pump basket
    The lid on my pump basket is on so tight that I cannot get it off.
    My pump won't prime either.
    Any ideas on how to get the lid off?
    Josh Ulfers - TFP Supporting Vendor - - 888-725-8766 - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Mar 2007
    Coastalish 'down easter'
    Brook, welcome to TFP!! Without knowing which pump you have, it's very (!) hard to help you. There is a sticky in the "Pool School" section which tries to explain the need for specific info about your pool when asking questions (the person who wrote it is awesome!!! ) Without knowing you pump, you can try to loosen the lid with the pump running - this often works. Other pumps have 'torque points' which can have a 2X4 or wrench applied to them so as to facilitate lid removal.
    If you'd post back with the pump type, someone here is almost sure to have a similar model and can give you specific help 8)
    Again, welcome to this forum!! we will do our best to help answer any future questions you may have!
    Luv& Luk
