Results 1 to 9 of 9
Thread: Converting - pool calc problems...
    I've tried to use the pool calculator and it isn't working. Want to switch to chlorine from baq have a ua and I don't know how much bleach to use. I have an 18 round pool
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    Re: How to convert a Baquacil pool to chlorine
    sorry - 18 round pool
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Here's the instructions for using the Pool Calculator:
    http://www.troublefreepool.com/pool-...ool_calculator
    What part are you having trouble with?
    Re: Converting - pool calc problems...
    I just saw your post so went back and saw how to get the pool gallon amount. I read some other posts and I'm getting so confused. I thought I have to get it up to 15ppm thenI read someones post that said FC is at 4.5 and tht was good. HUH? I have to read more!
    Quote Originally Posted by mudpie13
    Have a look at my thread, Positronic, as I'm on day 13 of the conversion and am almost done. It should help give you an idea of how it'll go. Basically you have to keep the FC at 15ppm to get rid of the baquacil until FC drops only 1ppm or less overnight (test just before dark and at dawn). For the first few days test FC and use the pool calculator as often as every hour or two if you can (helps speed up the conversion process) and add bleach to keep FC at 15ppm.
    POOL SPECS - 18' round AG pool Doughboy pool with 5'8" deep-end, Aqua Trol Salt Water Generator, 1HP Doughboy pump, Doughboy sand filter, Solar Dome cover and a 40'x4' solar heater. Located in Oregon with swimming season from end of May through September. I pull the pump & SWG during winter months. Solar Dome minimizes FC loss & keeps heat in & debris out. Btw - Solar Dome lasted about 6 years before plastic started shredding.
    11,969
    This is what you need to do:
    http://www.troublefreepool.com/pool-...ine_conversion
    If you aren't sure about what steps to take, post a full set of test results, and ask any questions.
    If you don't have a good test kit, you will have to have one in order to complete your conversion.
    Test Kit Comparison
    I did get a good test kit that was recommended. Last night at 11:30, it tested at FC 17. This morning at 8:30, FC was 13, Added the recomended amount of bleach. Waited until 11:44, bact at 1.5.
    Now, I'm wondering if I should add bleach at all during the day when the sun just eats it up anyway. If I just add the bleach at night (just did that at 8:30) test at 10:30 then again in the morning, should I evenbother adding chlorine then if its gone down?
    I will post more test results tomorrow.
    And Positronic, I have been reading your posts. You all sound like chemists.....me, not so much.
    You are nearing the end of the process, when chlorine is used up by sunlight much more quickly than it is being used up by baquacil. At this stage it is a more efficient use of chlorine to only add chlorine in the evenings.
    OK, tested this morning at 6:30, FC 16.5, CC .5, TC 17. Just tested now at 12:10, FC 11, CC 0. It's rainy and cloudy right now. I will add bleach and test again later.
    BTW, my pool has been blue and clear for several days now. I just hope I can keep it this way once the conversion is over. Haven't used bleach in probably 8 years or more.
