Thread: NIghtlighter above ground pool light
    Does anyone know if there is a way to change the bulb in it? Mine isnt working - only about a year or two old. Happens all the time and we keep replacing them.
    Thanks Cathy
    24' round AG pool, 52" high,; Waterway 2 spd Pump;
    150 Sq ft. Clearwater Cartridge Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: NIghtlighter above ground pool light
    If it is an NL50, it should come with a "locking tool" to loosen the ring and remove the lens so you can replace the bulb.
    22,551
    We have the NLMC and it's not too difficult to replace the lamps. As Woody said it should have came with a tool the release the locking clip and then you can unscrew the lens. Even without the tool you can pry the locking tab back with a flat balde screwdriver.
    A word of caution: When installing or replacing the lamp wear clean cotton gloves to handle the lamp(s). Even a very small amount of oils on the lamp will severely shorten the life of them.
    Jul 2009
    Eastern NC
    26
    I'm not at home so don't have the model # on our lights, but I'm pretty certain we have two of the 50s ... neither of which worked this year as the bulbs are bad
    Our local pool store does not sell this model bulb, but the owner looked it up & her price will be $40 each (that's half what we paid for each light!) My husband found what appears to be the exact same bulb (looks the same visually, has the same wattage/model #) at Wal-Mart in their standard light bulb section. Of course, that bulb does not say "pool safe" and we're afraid to use it without some advice.
    What are other Nightlighter owners using to replace bulbs?
    Thanks in advance!
    24' x 52" AG round - 13,500 gallons - 2hp 2 speed BaquaPure pump, Pro Clean cartridge filter, TF-100 Test Kit
    22,551
    If it's the same voltage and wattage it'll be fine to use. The pool safe part comes from the housing and transformer.
    Apr 2010
    East Texas
    9,626
    Post us up the part number of the Wally world bulb!
