Thread: Auto-Pilot Pool Pilot DG-220
    Jun 2010
    Montreal, Quebec, Canada
    2
    Hello to all! First post, please help if possible!
    Just purchased the Pool pilot digital 220 and would like to install into an outlet (plug-in type). Already did the conversion from 230v to 115v in the unit itself, as per the instructions. Now, if I were to connect it to a 3 prong type plug, which wires go were? Reason: I want to put a power bar-surge suppressor between my Pool Pilot SWG and electrical.
    The diagram the supplied doesn't say which is line and which is load terminal.
    I have an intermatic timer that the pump is attached to, but never use it as electricity here is dirt cheap. Pump runs on 115v, to the timer and a dedicated circuit into the circuit breaker box. I have plenty of room in the cabana for electrical add ons.
    I did call customer service (Daniele) but frankly, didn't help at all. Disappointed. Hopefully, I'll be able to find more knowledgeable people here!
    Thanks a million!
    Jay.
    18x36 vinyl inground, appx 29k gallons
    Sta-Rite Max-E-Pro 1hp pump on 115 volts
    Sta-Rite S7MD60 modular DE filter
    AutoPilot Pool Pilot DIG-48
    S2325 - 16MIL 18X36 Ultra Clear Solar Cover
    Kreepy Krawly
    1 skimmer, 1 drain
    1.5 inch piping underground, 2 inch to all aboveground connections (pump, filter,swg) back inground with 1.5
    Ft Lauderdale, Florida
    1,455
    Re: Auto-Pilot Pool Pilot DG-220
    This is in the manual.
    AC LINE IN (Wiring diagram also located on inside of cover): select the diagram that matches your application.
    For 230 VAC; Brown (Br) = Line 1, Blue (Bl) = Line 2, Green w/Yellow Tracer (Gr/Yel) = Earth Ground
    For 115 VAC; Brown (Br) = Line, Blue (Bl) = Neutral, Green w/Yellow tracer (Gr/Yel) = Earth Ground
    So, for your cord, usually the larger slot is the Neutral.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Jun 2010
    2
    Thank you very much, the problem is now resolved! Next purchase in the list will be a heat pump...
    Kreepy Krawly
    1 skimmer, 1 drain
    1,455
    Sweet. Did I mention, by the way, that we also manufacture the AquaCal Heat Pumps? heh heh heh
