Thread: Adding cya
    Jun 2010
    Central Indiana
    92
    Adding cya
    I have a small intex AGP with small cartridge filter and want to add some of the granular cya i purchased from walmart. What is the proper method for doing this?
    13500 gallon AG (24' round), 100 sf cartridge filter, Hayward 1hp pump, pool 10-15 years old with recently replaced liner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Adding cya
    Put it in a sock and tie the sock in front of the return flow of water, where it will dissolve slowly. Retest for the CYA in 5-7 days.
    Jun 2010
    Central Indiana
    92
    Re: Adding cya
    like a regular old cotton sock?
    I broadcast a small amount per the bottles instructions. how long should I wait until adding more..othing is showing up yet when testing?
    11,969
    Re: Adding cya
    Takes up to a week to register.
    Yup, an old sock.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Adding cya
    Quote Originally Posted by frustratedpoolmom
    Yup, an old sock.
    My old socks tend to have big holes in them. Won't the powder run right out the toe? :P
