Results 1 to 7 of 7
Thread: CYA- how often would you add under normal conditions
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I've had my pool open three weeks- I've added CYA at first- about four pounds.
    My readings show about 30 that I've check about every ten days.
    Under normal conditions- how often would you add normally?
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CYA- how often would you add under normal conditions
    In the spring, and maybe a little to top it off in August if the summer has been wet. Most years just once.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    What he said. I might add that if there's something abnormal, you may need to add more. By abnormal I mean: plumbing catastrophe where half the pool gets emptied; torrential rains where the pool overflows; 400 pound neighbor entertains the kids by doing cannonballs.
    Apr 2010
    Buckeye, AZ 85326
    619
    Quote Originally Posted by Richard320
    HAHA I know that guy!
    Lots of good CYA info this week on TFP!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Thanks guys-reason I'm asking is- I test for chlorine and ph daily and am addiing a fair amount of bleach- probably 80 ounces a day and that barely keeps me at 3-4 ppm of FC. I have only tested for CYA a couple of times- CYA actually helps retain chlorine right?
    The trouble free pool method really doesn't seem to be the money saver over Pristine Blue that I thought it would be.... (if I'm implementing it like its supposed to be)....but the pool sure does look better!
    TFTest Kits TF-100
    22,548
    In Nashville your CYA should probably be closer to 50. 80oz is about twice what I use, your pool is a little bigger but not nearly that much bigger.
    Jul 2009
    S. California
    157
    I used a lot of bleach too until my CYA got to 40. Then it stabilized and less was needed each day. It took about 1 week.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
