Thread: Do you guys change your test kit every year?
    The manufacture recommends changing the test kit every year,that seems abusif to me.Has anybody tested older reagents to see it they still do a good job.
    Thanks
    42,000 liters inground pool
    swg aqua rite
    Hayward super filter sand
    Vinyl lining
    Haward 1.5 hp pump
    Re: Do you guys change your test kit every year?
    bats, Check your private messages, see the new messages button just below and slightly to the right of the TFP logo on the top of every page.
    Jul 2009
    Long Island, NY
    267
    Jason,
    I have the same question. Please PM me also.
    Thanks
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    poolneophyte, I wasn't answering bats' question, rather I have some unrelated things that bats needs to deal with.
    On reagent lifetime: All of the normal reagents will last several years if they are stored properly. You want to store then in a cool dark place with uniform temperatures. They can be damaged by extended periods of high temperatures, lots of direct sunlight, freezing, and by repeated rapid temperature swings.
    The FAS-DPD titrant and the PH reagent have the shortest lifetime, still at least three years with proper storage. Most of the rest will last quite a bit longer if you are careful with them. Almost all of them can go bad much more quickly than that if you mistreat them.
    30,432
    Taylor Technologies, the manufacturer of the chemistry for the two most popular kits (TF-100 and K-2006) recommended on this forum, advises that you should change the chemistry every year.
    Experience tells many of us that proper care of the kits (mostly keeping them indoors in an air conditioned, heated environment) will allow them to last noticeably longer.
    Officially, I think one year will always be the recommended replacement time. Your good common sense will probably allow you to extend that somewhat.
