Thread: drain and refill
    drain and refill
    I have a 300gl hot tub that needs to be drained and refilled, What steps should i take to clean all the piping prior to refill?
    16,000 gallon outdoor in-ground 16'x32' Kidney painted concrete pool; Hayward super pump, Hayward pro Grid 3620 DE filter(using Fiber Clear). No Heater. 250 gallon stand alone Jacuzzi hot tub .
    Feb 2010
    Houston, TX
    Re: drain and refill
    Before you drain, use a flush like Spa Purge or Spa System Flush to clean out the pipes. Make sure you remove the filter before doing it, and just follow the instructions on the bottle. If you've already drained, just refill and use the flush, then drain again.
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Flushing and removing the filter is important - especially if your water is extremely hard. We have a hot tub and an above ground pool that we empty and refill regularly, there's nothing to it really.
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    Jug dumper apprentice
