Results 1 to 14 of 14
Thread: Chemical to keep bugs off water
    I was told that they have some kind of chemical that you can put in your water to keep the bugs from landing in it. I dont really believe that is possible but who knows. Has anybody heard of it and does it work?
    Intex Easy set 18x48 pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Chemical to keep bugs off water
    Similar to the chemical that turns urine red, I don't think it actually exists. Anything that would repel bugs probably would do a good job of repelling people as well.
    Adding borates to the water will stop some kinds of bugs, but not others, from hanging around the pool.
    Aug 2009
    North Central Texas
    1,358
    Now that you mention that, we've had mosquitoes out and biting for months. I haven't had to using any repellents, usually coils, around the spa when soaking, since I started using borax in my spa (at the maximum end of target). I don't use much borax in the pool, though, because of the dogs drinking from even when they are swimming. Squirrels and I'm sure nocturnal critters drink from my pool a lot too.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    They have a chemical that makes the bugs sink. Does something to the water surface tension. Maybe that's what they were talking about.
    Love TFP? Become a
    TFP Supporter!
    why would you want them to sink. easier to get off top with skimmer or net I would think
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I thought it turned it blue
    Louisiana
    127
    Maybe it is too early for me or bogus but a local pool place told me to use ProTeam Prevent algeaicide and it would also kill the bugs. Something about a layer on top of the water and when they come up for air it kills them. Not one swimming in pool but seen a few dead.
    27' Radiant Metric, 17,100 gallons
    Pentair Dynamo 1.5hp 220v
    Circupool RJ45, Sand Filter, Borates
    Dolphin DX6 Robotic cleaner
    TF 100 Kit
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    I remember last year we had these brown hoppy type bugs (backswimmers?). As soon as you'd skim them out of the water, they'd jump right back in. The solution we used was when skimming them out of the pool, to immediately drop them in a bucket of water that was sudsy with Dawn dish soap which I believe suffocates them and they did die.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Feb 2008
    Denton, TX
    5,061
    Interesting thread.
    Borates do a couple of things. First off, 50 ppm of borates does lower the surface tension in the water. Bugs that depend on good surface tension to remain on the surface of the water will find it much more difficult to do so with borates in there. This usually means that they will sink to the bottom. Birds will also get waterlogged more easily as I have personally discovered. Borates are also toxic to many insects. Boric acid is a commonly found active ingredient in pesticides designed for roaches. It isn't a contact poison though (typically used as a bait) and typically only works if the insects consume it.
    Yes there is a product that does this. I use it every sprint and summer as we have a lot of flowering trees, bushes an plants.
    It goes by several names One is Bug Off by Lo-Chlor. Another is called GLB Bug Out both pretty much the same thing. I have been told you can also use the algicide Skillit I am testing this one this season as it will eliminate the need to purchase a second chemical since I will change to skillit as a preventative algaecide this season.
    All three products break the surface tension of the water which allow bugs like wasps hornets bees and sometimes flies etc to land on water.
    By removing their water supply you will notice a dramatically reduced numbers in one season as they move off and change their nesting zones to a more hospitable area.... Some neighbor down the street.
    20x40 ~30,000 gallon IG vinyl pool
    Hayward S310T2 sand filter (30.5" 500#)
    Hayward Super Pump 1.5 HP
    1.5" PVC, 2 skimmers, 3 returns
    Polaris ATV
    Covers: solar and loop-loc
    38,301
    Welcome to TFP, creativone!!!
    I just wanted to point out that we do not recommend (or need) an preventative algaecide. The methods we teach are based on maintaining the correct level of chlorine in the pool. If you do this, there is no need for algaecides ... save your money!!!
    Feb 2013
    Goodyear (Phoenix), AZ
    9
    I know this post is a couple months old but my pool just got finished being built about 3 weeks ago and I have an issue with yellow jackets that has gotten progressively worse. At first it was a few here and there but now its 2-3 every 5 minutes during the day and it has made swimming in the very expensive new pool not possible as we have already been stung. I have tried adding borax and muriatic acid to bring the borates up to 50ppm to hopefully decrease surface tension so they could not land but that has not worked, they can still land. I cannot locate the hives, I've tried they are not on my property and I can only follow them so far, it seems there maybe multiple hives. I've tried luring them with baits to a different location, fake hives, etc all to no avail. I really think my best shot is to make it so they don't like the water. The local pool store has recommended Skillit and the companies web site even says it helps get rid of bees and wasps. After reading here for a while I am very wary of the local pool store. I'm really desperate any advice on trying skillit or another solution that may work?
    25,500K gal, IG, Cartridge, Pebble, Pentair Intelliflow 1800rpm/3450rpm
    Well I've never used the borates method. But as I've mentioned above there ARE two specific products that are (NOT algaecides) both pretty much identical that are specifically for this purpose.
    I know at least one of them can be ordered online. I think GLB (named after the chemical in it) may be available only to one store franchise. Paddock pools at least locally... but i may be wrong. And work great on the hornets and yellow jackets. But keeping toys and hoses out of the pool where bugs can rest on them to drink will help also be necessary when they are not in use.
    Looking for the nests/hives doesn't really work too well because as long as they have a water source (your pool). They will fly several houses away or farther to get to their nests. And they can hide these things well. They fly around sporadically. Not like bees where they fly home frequently.
    Polaris ATV
