Thread: First Test
    First Test
    Well got my kit today... This is way cool. I was expecting a small kit LOL. This this is huge. TF 100
    I prob should have waited till the evening but owell. Will do it again then. Im sure i prob messed up something. First let me say I have tabs in my chlorinator Im going to go remove them right now. Cut my filter back to 8 hours a day. Been running it 24 7 for about 4 days while I got rid of some algae.
    1st #s
    FC 9.5
    CC 0
    PH 7.5
    CH 200
    CYA 38
    33x52 AGP 25600 Sand filter 1.5 HP Hayward
    Mar 2010
    Spring, TX
    1,082
    Re: First Test
    If you still have algae I would still run it 24/7 until you get rid of it.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: First Test
    Quote Originally Posted by jck
    1st #s
    FC 9.5
    CC 0
    PH 7.5
    CH 200
    CYA 38
    The 38 CYA is a guesstimate, I hope. If the tabs in the Chlorinator have CYA in them, leave 'em alone. They'll raise the level up to 50 or so at no additional expenditure. When you get to where you want, pull them out. Or just don't refill it.
    30,414
    Re: First Test
    jck,
    How does your water look?
