Results 1 to 12 of 12
Thread: Wilkes pool liner pulling away - Please, still need help!
    Nov 2009
    Cleona, PA
    236
    I have this happening in two spots, how do I fix it?
    [attachment=0:3e4xm7qt]PIC_0298.jpg[/attachment:3e4xm7qt]
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward Power-Flo LX SP1580, 1HP
    Hayward S-160T High Rate Sand Filter
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Wilkes pool liner pulling away
    Is this a beaded liner? Looks like it pulled out of the receiver. If it is a Unibead/JHook you would need to remove the top rails and stabalizer track on that corner and put it back on...unless it is ripped? Can't tell from that picture..
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    22,549
    The experts will be along soon but looks like it needs snapping back into the receiver. You may need to heat the liner to stretch it back into place.
    Nov 2009
    Cleona, PA
    236
    I found these below the corner pulling away. Does this help? What are they?
    [attachment=0:1fz07po4]PIC_0304.jpg[/attachment:1fz07po4]
    Nov 2009
    Cleona, PA
    236
    Ok, I took some more pictures, and also looked at one of the corners that wasn't pulling away.
    It seems that they used the white clips to wedge the liner in.
    [attachment=1:362sd954]PIC_0306.jpg[/attachment:362sd954]
    But they should have folded the liner around the white piece, and then wedged it in, like this:
    [attachment=0:362sd954]PIC_0307.jpg[/attachment:362sd954]
    My question, how can I heat this up so that it stretches? What process should I use for this?
    Nov 2009
    Cleona, PA
    236
    Bump.
    Please help, my chemicals are now balanced, but I'm afraid to have people in and get water splashed behind the liner. How can I fix this?
    Nov 2009
    Cleona, PA
    236
    Re: Wilkes pool liner pulling away - Please, still need help!
    Should I try this myself? Or hire somebody?
    Will I need to lower my water?
    I don't think I can let people in until I do this, the water will very easily splash over and behind the liner.
    I tried stretching it myself, but could not. Didn't try heating it tho.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I'm sorry the folks "in the know" haven't responded yet. Let me see if I can find someone who can offer some tips.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Sorry I can't help, but you're not being ignored!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Sorry for the delay!
    Give this for some tips.
    There's no reason not to use the pool. A little water behind the liner will be forced out by the water in the pool.
    You posted on my daughter's 13th birthday and the following week was the busiest for pool dudes - again, sorry!
    Luv& Luk
    -Ted
    Nov 2009
    Cleona, PA
    236
    Striking out on local places to hire to do this. Either they won't do it because they didn't sell it, or we're not local enough.
    Wife and I tried to do it last night, got a little back in the track, but I think I'm going to have to lower the water level....
    Nov 2009
    Cleona, PA
    236
    Okay, it's decision time...
    I can either:
    A) Drain the pool now, maybe half way, fix the liner, and fix the return fitting that's leaking
    B) Hold off until the end of the season on every thing and drain and fix
    Other thoughts... I've been thinking about adding another suction port for vacuuming. When/If I drain, I would probably want to do that then. (more towards the middle of the pool)
    What are your thoughts? How much $$ and chemicals could I lose this way?
    If it was your pool what would you do? (Be honest, I can take it.)
