Results 1 to 12 of 12
Thread: Just finished hard piping my setup
    Western Pennsylvania
    151
    Just got done hard piping, How does it look to all you long term pool owners?
    I did notice a small flaw in my bypass for the natures2 filter but thats an easy fix.
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    white settlement,texas
    2
    Re: Just finished hard piping my setup
    GOOD JOB JUST DID MINE LAST WEEK
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    Well done, Looks pretty good.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Well, since mine is a 16x32 AGP 4 ft. deep I can't call him my pool "builder"............but mine is dug down 2ft. and my pool "erector" made all my connections with pvc as well. Pump station is sitting on a nice level plastic pad they use for air conditioning compressors and the like. Almost gives you that "in-ground" pride feeling!
    151
    Thats the one thing I should have done was build a better pad.
    Sand filter
    Jandy gas heater
    Intermatic timer
    Whats the black thing on the right that is plumbed into the system?
    24' Round 14K Gallons
    Hayward S180t Sand Filter
    1hp Hayward Powerflo Matrix Pump
    Aquabot Pool Rover Jr.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by britinusa
    If you want to make it look "right," you'll need to add a lot more elbows. And lose the unions - you must imagine that you've just built perfection, and that no one will ever need to work on anything you graced with your touch for the rest of eternity. Too late to tee them in, probably, but you could pound some PCV scraps in the ground near the pad, then cap them. That way no one will know where they go (if anywhere) and will be afraid to uncap them or saw them off flush, again, for the rest of eternity.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Looks good...the only comment I have is to watch for leaks as it looks like those elbows are dwv vs sch 40 fittings...ie not rated for pressure. Also, as Richard mentioned, I am assuming that union on the nature2 bypass is the flaw you mentioned?
    151
    The unions are there so I can remove the pump and filter during the winter.
    The black thing is a natures2 system it allows us to use less chlorine as my wife and son have sensitive skin.
    The flaw is that I need another valve on the other side of the natures2 where the union is, I should have removed that union and put a valve in there so I can bypass when I am using metal remover, you said about more elbows, where do I need to put them in?
    Sand filter
    Jandy gas heater
    Intermatic timer
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    it's fine...not sure about more elbows? Anyway, my comment about the union by the nature 2 is that unless there is a union on the bypass that is not visible in the pic, that union will not work. Other than that nice job, but do watch for leaks. The elbows you used are not pressure rated. Sch40 fittings have a lot more glue surface like the unions and tees you used.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Quote Originally Posted by Richard320
    Richard is yanking your chain! Your set up is fine! (Hey Richard ! )
    Love TFP? Become a
    TFP Supporter!
    151
    Thanks for the comments guys, the union by the natures2 was from my first part if install last year when I put in a heater, from the skimmer to the natures2 was all flex pipe, I just left the union in before i realized my mistake.
    I will watch for leaks on those elbows, I did get them from somewhere else this time but the other elbows on the heater have more glue surface.
    Sand filter
    Jandy gas heater
    Intermatic timer
