Thread: Well Water
    Howell, MI
    9
    Well Water
    Is it ok to fill the pool using softened well water or will this kill my water softner? I have 2 spigots near the pool, one is hard water right from the pump and the other is from the softner. thanks.
    20K gallons, DE filter, above ground, 1 HP pump, 2400 gallons per hour
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Well Water
    I guess that depends on the regeneration capabilites of your softener. We just had another thread where someone used theirs to fill the pool.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Well Water
    Welcome to TFP.
    Your water softener will need regenerating many, many times in order to fill the pool. The best thing to do is to test your unsoftened water, particularly for Calcium Hardness, Total Alkalinity and metals before you put it in the pool. This way you can seek alternative water sources if any of these are in an unacceptable range. Metals and calcium are the real kickers, since there is no cheap or easy way to remove them from the water, and the expense of buying water is usually far better than having to deal with them.
    Check out this article Recommended Levels for the kinds of levels you are looking for in your well water.
    Howell, MI
    9
    Re: Well Water
    Thanks. I bought this house 1.5 years ago and it came with the pool. I just filled it with the hard water right from the well last year and it took over a week to get it clear. I didnt really know what I was doing (and still dont) I was just talking water samples to the pool store and adding whatever chemicals he sold me. Seems like I was probably getting ripped off so I want to learn a little more this year before opening the pool.
