Pump it out of you can safely. Especially so if it’s clay soil.After 2 years and 1 month to the day we were so excited to begin digging this week and after a nice start to the week, heavy rain cam swooping in for 2 straight days and nights.
Should we be concerned about water holding in the dig site or should we get a pump and start emptying it out?
View attachment 478652View attachment 478653
pool builderAre you doing an owner build or having it built by a hired Pool Builder?
That has to be run off. The frame will exend above soil line. There's a giant mound of dirt that's left over. The PB said that they will grade away from the house and pool and thwere will be drains in the concrete to handle the runoff.That's an awful lot of water; how much of that is runoff? I'd be shocked if that's all vertical deposit. But then again I'm a desert dweller so maybe 2ft of water is normal for 2 days of Ohio rain.
*Edit: I zoomed in in the shovel. That's a heck of a lot more than 2 feet of rain.
You definitely don't want your pool to be a low point in your landscape. Will the frame extend above the soil line?
Thanks! I did that and they are unsurprised by it. They have the materials for the pool starting to get delivered and will evaluate and drain it when they get onsite this week.While it may be on the PB schedule - call them anyway and advise that they need to pump the standing water out of the hole. This is better than them showing up to do more work, seeing the issue and needing to delay further work because they were unaware of the standing water.
I'm thinking it came off the house and followed the plumbing trench to the dug pool area. Do you have any downspouts that drain across that trench ?That has to be run off.
Discovered a clogged down spout. Will get that cleared this weekend.I'm thinking it came off the house and followed the plumbing trench to the dug pool area. Do you have any downspouts that drain across that trench ?
