Thread: Tips for pressure washer purchase
    ktdave's Avatar
    Katy, TX
    888
    Looking to buy a pressure washer. What size (PSI) do I need for general purpose cleaning (driveway, pool deck, privacy fence, hardi-plank)? Any comments/suggestions are appreciated.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    We bought a cheapy electric one at HD a few years ago, and it works just fine for those purposes. 1300 PSI
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Mine is 2800psi, and it will cut into the concrete if you want it to. I'd recommend a Cat pump and Honda engine combination if going with gas. Nothing cleans like the hot water units, but they are serious money.
    From_Arizona's Avatar
    Glendale, AZ
    212
    I have had experience through my dads company with the heavy duty high pressure gas and heated pressure washers, but would not want to use one for household cleaning since it does not have the built in "OOPS Factor" that the smaller electric box store brands provide.....
    When you are doing the home cleaning as you would use it for, you want have the "oops factor" built in, which they do:
    - oops I shouldn't have hit that window, at least it wasn't the high pressure model that would have broken the glass
    - oops, it looks like I lifted a corner of the paint on the wall...vs. removing a wide strip of paint
    - ooops, the wand slipped and hit my foot, it might hurt but at least it didn't remove the skin
    Don't get me wrong, the small units can cause damage, but for between $100-150 you have a quality tool that you would feel comfortable giving a novice to use on most surfaces.
    I use my HD model to wash my patio, house, car engine, etc and previously used it on teh last pool to clean the water line scum off the pool. I highly recomend as a must have for the home.
    1980's Shasta built 30,000 gal inground diving pool. Pebble-tec interior. Pentair DE Filter. In ground pop-ups. Hayward Navigator sweeper.
    ktdave's Avatar
    Katy, TX
    888
    Thanks guys! Yeah, I think I am looking to go economical and oops friendly.
    Pool School
    TF Test Kits
