Results 1 to 9 of 9
Thread: Shock weekly? Do I have to?
    Nov 2009
    Cleona, PA
    236
    I was reading some product descriptions (don't have them in front of me) and it said you should shock weekly with them. If I maintain FC and pH, do I need to shock weekly?
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward Power-Flo LX SP1580, 1HP
    Hayward S-160T High Rate Sand Filter
    Re: Shock weekly? Do I have to?
    No, as long as you maintain your levels properly there is no need to shock weekly. We recommend shocking only if FC goes to zero, if there is visible algae, or if there is obvious organic contamination of the water.
    Many places recommend weekly shocking because they assume that you are going to ignore the pool during the week and let the levels get out of range and then need things cleaned up for the weekend.
    Nov 2009
    Cleona, PA
    236
    I thought so. (or at least figured they were looking to sell more product.)
    The weekend is when I'll use it most. I may do an overnight FC loss test on Sunday night, just to see how hard the pool was handled. Then I could do a small shock to the pool if necessary before the wife and I go to work.
    Feb 2008
    Denton, TX
    5,061
    They also recommend this frequency because this allows them to make more money off of you since you are buying lots of bags of so-called "shock".
    You will find that most who go the BBB route rarely have to shock. I have had to do it once and that was because I dropped the ball and let the FC get to zero.
    Nov 2009
    Cleona, PA
    236
    You always shock when opening, tho, right?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by mkenyon2
    Not necessarily! Just depends on your water test results
    You're done SLAMing when:
    Nov 2009
    Cleona, PA
    236
    FC about 0 right now. (Still have the cover on, and the water is pretty clear.)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Nope, haven't shocked for last three openings... haven't needed to-still had FC left from winterization.
    If your water is clear but your FC is zero, raise the FC up to your "target" for your CYA level, and then do an overnight test. If it's holding, and the CC is .5 or less, you don't need to shock.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    ditto...I just ran my pool rover under the winter cover and tested afterwards FC =6.5 and no CC's ...can't wait for things to warm up a bit and get that cover off.
