JasonLion said:I thought it might be interesting to see what kind of winter cover people use.
ChiknNutz said:Is it necessary to use a true winter cover? Where I'm at, it does sometimes get in the teens for a couple weeks, but it usually hovers just at or above freezing for the bulk of our winter. We usually get little snow, though the last couple years we've seen upwards of 18 inches...which is very unusual. We have no trees around our pool and it is all fully fenced. So, what is the primary purpose of a winter cover? Thanks much, still learning!
tim_pool_newbie said:So I'm curious if anyone else has ever upgraded covers like that, and what kind of trade-in value they received for the original unused cover. I'd also be interested to hear what others have paid for mesh safety covers, and/or if anyone has a particular brand they recommend.
The main thing is to blow out the lines properly. In areas where there are extended periods of hard freezes, this is critical. Typical air compressors that homeowners have are not really made to do the job, either. You really need a low pressure, high CFM type of device (i.e. a mighty vac) although a simple air compressor could work in some cases. Biggest reason I pay for a close is that if lines freeze up or the heater is damaged, it's on them, not me. :-DChiknNutz said:What is the big deal about having someone come out and "professionally" close your pool...what all do they do?
When do you close and when do you open? What is your water temperature when you close?ethany said:I wish I purchased the solid cover,I have the loop loc mesh and every spring when i open its swamp green.
GEM said:Only thing to watch is that you don't get too much water over winter and potentially pop your coping stone with ice from below.
chezhed said:It's not so much a winter cover as it is a falling leaves cover! We have lots of oak trees in the yard. I take an oversized leaf net and drape it over a cable I string between the house pergola and a tree and then over the pool and anchor the sides with water tubes. (I tried pavers once, but the weren't enough weight once the net gets covered with wet leaves.) I blow off the leaves periodically and the pump runs every day so we get our waterfall effect and this way we can still enjoy the view of the pool to some extent. It goes on before Thanksgiving and comes off about New Year's.
It's a tent, not a cover
