Thread: My pool won't shock!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I thought it would be a good idea to shock my pool. So I plugged in a hairdryer and tossed it in. Nothing. Am I doing something wrong?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: My pool won't shock!
    This is BBB...you should have used a Blender.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I think the main problem is posting 4 days late. Oh, f only you'd been in time...
    You should install a 250HP Diesel powered Hayward pump and put in more sand. That will fix ya right up!
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Quote Originally Posted by Ohm_Boy
    I think the main problem is posting 4 days late. Oh, if only you'd been in time...
    I concur...
    "April Fool's is gone and passed, and you're the biggest fool at last!"
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
