Results 1 to 15 of 15
Thread: Filling with garden hose, how long?
    Feb 2010
    16
    Approximately how long or how many gallons will be filled using a garden hose per hour? I'm wondering how long it will take to fill 10k of pool water... Thanks.
    Guest
    Re: Filling with garden hose, how long?
    Most pools fill within 24 hours. 10K is pretty small, so I would guess that you would be full in less than half that time.
    Dec 2009
    Central Massachusetts
    2,690
    Start filling a 5 gallon bucket and time how long it takes to fill it, then do the math.
    Example.
    If it takes 45 seconds to fill the 5 gallon bucket, thats 6.6 gallons per minute or 396 gallons per hour. So.. to fill 10,000 gallons it would take ~25 hours.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mar 2009
    eastern washington state
    275
    yes i would do the five bucket test, and putting two hoses in the pool, may or may not speed things up. sometimes when you turn on two hoses your pressure goes down and you don't get as much water.. take two hoses and do the bucket test to. Then you will know if one hose is faster or two hoses is.
    good luck
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    Two hoses is always better than one hose. Depending on how your plumbing is setup it can be anywhere from just a little bit better to nearly twice as good.
    Not to steal the thread but ive got a few questions.
    Is filling your pool practical with a hose? You say your pool is about 10k gallons, what does this cost you to fill or what per gallon? are there water delivery options?
    23000, Sand, IG, Plaster, Century Pool/Jetted Tub Motor 1.5HP, Rainbow Lifegard Feeder Model 300
    Dec 2009
    2,690
    For me, 10,000 gallons is about $35 worth of water. If i truck it in, 10000 gallons is $350, so ten times. When I first filled my pool, I used trucked in water since in the middle of the summer my town water has about 2 ppm iron (I filled my pool in the middle of the summer and didnt want the iron in it).
    But my tap water is cheap, YMMV.
    Yeah the question is relative to how much water flows through your hose. I too have an approx. 10K gallon pool but i have a well and a pump that puts out about 30 gallons per minute. City water supply is around 8 gpm here. I can fill mine in probably around 5-6 hrs.
    Then again there is my father in law who has an 88,000 gallon pool and fills it in 3-4 hours using a 10" pipe from an irrigation well.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Henry Porter's Avatar
    Nov 2008
    Sweden
    604
    Quote Originally Posted by socalpoolguy
    If you're not sure about the exact capacity of your pool don't forget to check you water-meter before you start filling.
    Inground concrete pool 14600 gallons,Pentair Whisperflo 3/4HP WFE-3, Hayward swimclear 420sq ft
    Zodiac LM3-24 SWG, Dolphin Diagnostic poolrobot, Heatpump Gullberg&Jansson 13,8KW, TF testkit.
    Seen a shooting star tonight And I thought of you You were trying to break into another world A world I never knew
    I always kind of wondered If you ever made it through Seen a shooting star tonight And I thought of you
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by Thinkly
    Say, what? I'd hate to be in charge of brushing that thing down every week!
    On the other hand, it'd be fun to say, "Come over and swim next weekend, we've invited... the town." He's certainly giving the YMCA a run for its money.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Feb 2010
    Central NJ
    53
    Also, if using your hose, don't forget to call your water municpality prior. Some will offer lower rates by removing the sewer portion of the bill when you fill your pool. They'll come out and take pre and post reading of the meter, adjust your bill accourdingly for the pool water, which will also give you a good idea of the gallon count.
    Rgds,
    Dominick (Inground Pool Newbie)
    650 sq/ft - 20k gallons
    Free-Form Gunite with Granite Ansylbrite Finish
    40 sq/ft 18' raised spa
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    Dec 2009
    2,690
    Quote Originally Posted by Dominick
    Eveyone sdhould check on something like this. My town, as others, set the sewer rates on the winter quarter water useage only. Any water used in the spring, summer, and fall is not used for sewer charges.
    Quote Originally Posted by polyvue
    Yeah it's one of the few private pools with both a high and low diving board. :P Also one of the few still around that was built in the 1930's. My wife's gpa built it himself and it has been used every summer since. He sets a patio table in the pool for the water column to crash on so it doesn't damage the pool i guess. The water is pulled from the ground by an old Minneapolis Moline tractor running the well pump. Creates a ton of water that is for sure.
    10,000 gallon
    NC KANSAS44
    Bethpage (Long Island), NY
    39
    Quote Originally Posted by Thinkly View Post
    I know this is an old thread but if you're still a member & read this post, I'd love to see a picture of this pool! Wonderful that your wife's gpa built it himself and wonderful that is has been in use for so many years.
    12 ft round above ground vinyl pool, 52 in depth (approximately 3600 gallons), non swg, Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 16-inch, 110-120V with GFCI, pool installed August, 2006 on sand, new liner installed June, 2014, fill with hose water (refilled in august, 2017), use tf-50 test kit, except use hth phenal red ph test.
    Oct 2014
    Nags Head, North Carolina
    4
