Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Teflon Tape how much?
    Jun 2007
    Alabama
    40
    How many times do you wrap teflon tape around a male connector? Or how many layers I should say.
    thanks
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
    Jun 2007
    Charleston, SC
    151
    It really depends on how loose the threads are. I typically find 2-4 wraps to be sufficient, you want to make sure you are giving it a nice tug as you wrap so they are nice and tight.
    18' Round ABG (8000 gallon)
    Hayward X-Stream Cartridge Filter
    1.5hp Hayward PowerFlo Matrix Pump
    80 sq. ft. solar panels
    Goldline automated solar controller
    Jun 2007
    Alabama
    40
    hmmmmm. I put two layers on and it didn't come close to tightening down all the way. I might try one, but then I'm worried it might not seal.
    Mar 2007
    Coastalish 'down easter'
    4,160
    The way I do it for new male adapters and females is to hold the fitting in my left hand hold the tape down at the base/ bottom of the M/A with a finger and wrap clockwise up the threads, back down to the base and back to the end where I rip the tape and smooth it. If either of the fittings are old, I'll add a thin layer of 'pipe dope' to the first ~5 threads, just to insure a good seal.
    Using too much teflon can crack the female adapter, use enough but not too much!! When screwing them together, go hand tight (as tight as you can get it bare handed) and then use channel locks or similar to tighten it 1/2 to 1 1/2 turns.
    Luv& Luk
    -Ted
    10 wraps no more no less
    30,431
    Sorry, Poolio, but 10 wraps of teflon tape is crazy. It sounds to me like you read that somewhere but have no experience with teflon tape. You are begging to crack a plastic housing with 10 wraps.
    Pool60, listen to Wolfmarsh....2-4 is exactly right.
    Jun 2007
    Alabama
    40
    Well so far I've tried 1, 2, and 3 wraps and I've gotten leaks with all three. It is a new male adapter going into the pump. This is frustrating
    What about using the teflon that comes in a tube? I'm thinking of trying that next.
    Jun 2007
    Charleston, SC
    151
    Just put another wrap or two on there and try again. Like I originally said, it depends on how tight the threads are to begin with.
    With many of the fittings I've had to deal with lately, I found I'm needing more and more layers of Teflon - 10 isn't that far off, now maybe it's the tape that's getting thinner, or maybe the male fittings are getting smaller, but I just added a bunch of plumbing to my setup and I must say, I was also using about 10 wraps, and nothing even came remotely close to cracking, probably could have even used 2 more wraps - and don't even start with the "no experience"
    30,431
    Matt,
    I have to assume you tried less and it leaked.
    Manufacturer's recommendations and a couple of plumbers I have spoken with all indicate 2-4. I have done maybe 200-300 joints with Teflon tape over the years using 2-4 wraps with a leak incidence of maybe 2-3 joints during that period.
    The leaks I had were on larger (1.5") brass fittings which I have since learned do much better with pipe dope. As best I remember, I've never had a PVC joint leak.....even 2".
    Ohio
    217
    hi pool60
    my pool installer who builds thar own shells and installs them and has done this for thirty year instructed me to use 14 raps of teflon tape then hand tighten as hard as i could then tighten half more with wrench. I havent had problems with any thing following this. I think your going to get a lot of ansers on this one and will have to pick one out.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    Jun 2007
    Alabama
    40
    By wraps do you mean times around? Maybe that's where the confusion is. When I said wraps, I meant layers. It was probably twice as many times around.
    Ohio
    217
    yes in my case i ment 14 times around so really it might be thinner in some areas. I was also told to always remove the old tape which i do but it can be a pain.
    Ric W
    My Pool
    Yes duraleigh, I've tried and had leaks - it's all been 1.5" grey fittings lately that seem to require about 10 layers, mind you I stretch it well into the grooves as one should - never apply loosely and never apply reverse threaded - meaning when you put the fitting on, it should not unwind the tape, it should try and wind it tighter.
    I try not to reuse old fittings - it's nearly impossible to get all the teflon off the male portion.
    30,431
    Matt, et al, (I love using that "et al" thing....I think it means "and others".......I really hope it makes me appear smarter )
    Just a little off the subject....you indicated grey fittings. In the US, that's typically Schedule 80 PVC. Same in Cananda? It has nothing to do with what were talking about, I'm just curious.
    I have occassionally re-used fittings before. I've got a soft brass brush, similar to an outdoor grill grid cleaner but longer bristles, that does a pretty good job of removing the imbedded teflon from the threads. It has saved me a buck or two over the years and is quick and easy.
    I'm still puzzled by the variation in procedure. I was thinking perhaps the PVC in Canada was metric and may have had somewhat different tolerances within the threads but you indicated US measurements for pipe size so that's not it. To my knowledge, teflon tape is all the same thickness so that's not it, either.
    Quote Originally Posted by pool60
    If you meant layers you should have said layers. But you said wraps.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Quote Originally Posted by poolio
    No need for the attitude. Please check your pm's.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I guess I'm one of the lucky ones, too. I've never had to use more than 4 wraps of tape to get a good seal, on joints where I use tape.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2007
    4,160
    Matt,
    Dave, I usually use rolling paper when I 'do' joints
    Luv& Luk
    -Ted
  20. Back To Top    #20
    30,431
    You ex-hippies are incorrigible!!
    Ahem.....I am assuming the "ex"
