Thread: Amonia
    Mar 2009
    Charlotte, NC
    539
    Amonia
    Am I correct that amonia wouldn't somehow be formed from regular OTC dishwashing liquid & pool water, pool water winterized properly or not?
    If I'm incorrect, then I'll pursue this thread, if correct I'll not waste anyone's time.
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Amonia
    Dishwashing detergent in pool water would not produce ammonia. However, if a pool is "let go" over the winter or at any other time is allowed to get to zero chlorine levels, then bacteria in the pool can convert Cyanuric Acid (CYA) into ammonia.
