Results 1 to 11 of 11
Thread: What do you do with completed tests
    Oct 2009
    Marriottsville, MD
    17
    Just curious what everyone does with their completed tests - I mean, these reagents have all kinds of hazard warnings and so on, so how do you dispose of yours?
    22.5k gal. (est.) IG Dark Plaster Pool (2007)
    Jandy Stealth SHPM 2.0HP Pump ~100gpm
    Jandy CL460 Cartridge Filter
    Polaris 9300 Bot/Cleaner
    Jandy AE-Ti AE2000T Heat Pump
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: What do you do with completed tests
    Quote Originally Posted by autoxer
    Interesting question. I don't have a technical response to it, but I can tell you what I do. I flush the contents of the titrant/reagent down the drain with cold water and then place the plastic bottle in the recycling bin. I wouldn't do this if I had voluminous quantities left over (say, more than 100 mL) but tap water will dilute anything I've seen in a residential test kit.
    Treatment chemicals are another matter. I toss old liquid chlorine into the pool. Haven't needed to toss anything else -- but if I did I'd probably take to hazardous waste station.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jan 2009
    Cupertino, CA
    1,966
    I think the quantities of test chemicals are small enough that they won't be a practical problem if you dump them down the sink. They're not THAT hazardous.
    There's a brown patch of grass that my wife blames on me dumping test chemicals, which I'm not inclined to believe but not willing to argue about, either.
    --paulr
    BBB "Intermediate Swimmer"
    no-mas's Avatar
    Jun 2008
    FL
    405
    I rinse my test vessel with water and pour it down the sink. Never gave it a second's thought .
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    30,432
    I rinse my test vessel with water and pour it down the sink. Never gave it a second's thought.
    Me, too!
    gtm's Avatar
    Aug 2008
    St. Petersburg, Florida
    201
    I agree, Paul, but I found a somewhat different solution, pun intended. My wife is also dubious about my dumping the "chemicals" in the yard.
    My wife complains that my beloved dog Spot always pees in the same place by the back steps and says that it's killed the grass in a 6-inch diameter circle. This is true.
    About once a month or so the container that I put the used reagents (and the rinse water) into is surreptitously dumped on to the same "spot".
    So until I get caught I don't have to worry about being accused of killing the grass.
    Get a dog, train her carefully, and there won't be anything to argue about!
    True story, but just for fun ... Cheers, Gary
    Quote Originally Posted by PaulR
    --paulr
    15,000 gal. IG fiberglass pool w/ 1 hp Hayward Max-Flo and 250 lb. Hayward sand filter
    Located in St. Petersburg, Florida, and enclosed in a birdcage
    Mar 2007
    Coastalish 'down easter'
    4,160
    I do my testing in the field (i.e. poolside/ not at my house)
    I carry a ~2Qt, container and dump the tested samples into it. After I'm done with all the tests, I dip the container into the pool, to further dilute the sampled water (without letting the mix I've made enter the pool ) and dump that dilute mix at the edge of the lawn - i.e. at the treeline or in a drianline.
    The amount of chemicals in there isn't large and would probably be fine to dump almost anywhere, but I'm just cautious like that
    Of course Gary has a better/ safer place for that 'waste' water (Hi Gary )
    Luv& Luk
    -Ted
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I usually dump it back into the pool. Or I drink it (just kidding )
    BTW
    Most of the time I'm just doing a OTO and PH test.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    gtm's Avatar
    Aug 2008
    201
    Quote Originally Posted by waste
    (Hi Gary )
    Hey Ted. I'm still here, just listening more than talking during the season. So much to read! Sorry for the semi-hijack ...
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by gtm
    Best use of the word surreptitiously I've seen in a long, long time.
    Now, Gary, what's your wife's name and cell phone number... I'd like to have her take on this! heh heh
    __
    gtm's Avatar
    Aug 2008
    201
    Quote Originally Posted by polyvue
    The area code is 666, but I don't remember the rest.
    And before you all start in on me, that was a JOKE! No way you're getting the real number.
    P.S. Love that avatar, polyvue. I have a woefully neglected Celestron that pre-dates Hubble by way too many years.
