Results 1 to 7 of 7
Thread: Does anyone here put MA in their pool by pouring...
    estogo's Avatar
    Jul 2009
    Houston
    34
    ...it into the skimmer?
    15,000 gallon in ground plaster with hot tub. Chlorine Pool with Ozinator. 2 Skimmers
    SmartFilter 450/550 4 cartridge filter.
    2.5 HP Emmerson Main pump
    Hayward Super Pump II 3/4 HP pump for water feature.
    Hayward Tiger Shark robotic cleaner (LOVE IT!)
    3/4 Hayward Super Pump II 3/4 booster pump for Hayward Phantom cleaner (no longer used)
    Jan 2009
    Southern Nevada
    37
    Re: Does anyone here put MA in their pool by pouring...
    I do not it will or could cause damage, I pour it slowly out away from the side in front of a return and then I brush the pool surface to make sure it is mixed in.
    18,500 gallon, 16' x 38' freeform ig plaster w/ 7 ft spill over spa
    Pentair C&C+ 420 cart, Inteliflo 4 x 160 pump - new plaster on 5/5/09
    estogo's Avatar
    Jul 2009
    Houston
    34
    Quote Originally Posted by camelai
    That's what I've been doing too but I swear I saw someone on this site who said that they did and I was checking to see what's the preferred way.
    Now my pH is a bit high so I tried it (haven't searched to found the post) with just about 1/8 a gallon and the pressure temporarily dropped on my filter. Prompting an "uh oh" from me. Pressure went back up after a few minutes but wanted to check with the forum. After the 'experiment' I got to thinking, "well, if I'm not supposed to even put pucks in the skimmer then this can't be right...."
    Aug 2007
    near the swamp
    804
    Goodbye o-rings and seals!
    estogo's Avatar
    Jul 2009
    Houston
    34
    Quote Originally Posted by DBfan187
    That certainly makes sense. Glad I asked!
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by estogo
    Some people pour chlorinating liquid or bleach in the skimmer (with the pump running), but no one should ever pour acid into the skimmer. Muriatic Acid has a pH of -1 and even with very slow pouring the pH would still be around 1 which is very, very low. As was noted, you risk damaging components in your pump and elsewhere.
    Jan 2009
    Cupertino, CA
    1,966
    I remember somebody saying that they put everything BUT acid into the skimmer.
    --paulr
    BBB "Intermediate Swimmer"
