Results 1 to 10 of 10
Thread: cleaning scum ring
    cleaning scum ring
    i was just curious at to what different people use to clean pool scum
    ring and how effective it is.
    24,000 gallon ig fiberglass pool
    1 hp hayward pump
    hayward sand filter (250 lb)
    madisonville, ky
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: cleaning scum ring
    I've always just used pH up or baking soda paste on a green kitchen double sided sponge to remove oils and scum at the waterline
    Luv& Luk
    -Ted
    Guest
    I use tile soap. If there is any scale I mix it with muriatic acid.
    Jul 2009
    Shawnee, Kansas
    92
    I use Pool and Tile Cleaner from Leslies.
    Matt
    20,000 gallon, sand filter, IG vinyl
    PVille's Avatar
    May 2009
    Purcellville,VA
    39
    I get in the pool and use my hand to rub the ring. If it is really stubborn we have a soft nylon pad that was made to clean our ceramic cook top that we use and the ring come right off. I have a fiberglass pool and the surface is very smooth.
    In ground 15 X 33 10,400 gal. Fiberglass
    Two Returns, Two main drains, One skimmer
    Aqua Logic SWG, Hayward TriStar 1.5HP
    Hayward C3025 (325 sq /ft) Cartirdge Filter
    Solar Heater (Details at http://www.bakerlabs.com/solar)
    Hey guys, I ran across this post in trying to deal with the same problem and was on my way to the pool store to get some tile/vinyl cleanser when my wife suggested trying Magic Eraser. She had used it for removing scuff marks and other uncleanables when we moved.
    It was literally amazing. In less than 10 seconds I was able to clean a small area from dark grey to like-new. I took the plunge and cleaned about 50 linear feet of scummy poolside in about 15 minutes - no exaggeration - with very little elbow grease. Incredible. Here's a link to Magic Eraser - I strongly recommend it for fast cleanup of pool ring and scum.
    16ft x 32ft depth 3ft to 8ft rectangle inground pool vinyl liner 21000gal. , 3/4hp pump/w 200lb sand filter and erosion feeder using 3in. trichlor tablets
    I was going to try the magic eraser also, but it says do not use with chlorine bleach!
    18x33 above ground pool, vinyl liner, starbright DE filter, 1.5 HP Dynamo pump
    The magic eraser is fine for use with a swimming pool. The chlorine concentration is the pool water is way way lower then in straight bleach, so the avoid bleach rule doesn't apply.
    I use a microfibre cloth and clean each tile by hand from inside the pool
    They get so much gunk off sometime I need to use several.
    It Works very well and it quite gentle on the tile, at the same time I stay on top of it so it doesnt get too bad to start with.
    Heavy bather loads all using sunblock are the gunk builders for me.
    Uncle Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    tomzo's Avatar
    May 2011
    Escondido, CA
    77
    Just wanted to add my voice to the Magic Eraser method - just tried it and it worked perfectly. I would not call it abrasive at all and my 15 year old daughter went around the whole pool in about 15 minutes!
    21K Gal Vinyl In Ground with block wall sides (Self Built with help), Pentair Easy Touch controller, Pentair Intelliflo pump, Intellichlor salt system, Clean and Clear Plus filter, SR Smith Typhoon Slide
