Results 1 to 18 of 18
Thread: ? for intex owners
    fordman's Avatar
    Jul 2009
    Iowa
    119
    ? for intex owners
    Could you mount this to the side of a intex metal frame pool?
    1988 Ceder Ridge
    24' Doughboy AGP
    Re: ? for intex owners
    Fordman -- just and FYI that I couldn't see the image and no link or anything to open it. Maybe try to repost?
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    fordman's Avatar
    Jul 2009
    Iowa
    119
    1988 Ceder Ridge
    24' Doughboy AGP
    Jul 2009
    S. California
    157
    You could probably find a shade tree mechanic way to mount it, but I suspect that it wouldn't be practical. After 5 minutes of swimming with the Intex skimmer installed it was soon apparent that it had to go.
    And if you're considering cutting the liner and installing it outside the pool......yikes! Just sayin
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    fordman's Avatar
    Jul 2009
    Iowa
    119
    yeah I like the fact of a skimmer but don't like it inside like the intex are.
    1988 Ceder Ridge
    24' Doughboy AGP
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Fordman,
    There have been a few others that have asked or done this. Look at this one:
    http://www.troublefreepool.com/abg-p...ngs-t9502.html
    My plan is to find someone with an Intex that is tossing it, and use the material from that pool to create a "patch" that will be 2-3 inches larger than the outside of the skimmer. Just having trouble finding a donor pool. Do not want to use a blue one, as mine is the gray ultra-frame. If I cannot find a donor, I may use some PVC showerpan liner that I saw at Lowes.
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    fordman's Avatar
    Jul 2009
    Iowa
    119
    wow now thats what I want.
    1988 Ceder Ridge
    24' Doughboy AGP
    fordman's Avatar
    Jul 2009
    Iowa
    119
    but you would have to patch off the old holes
    1988 Ceder Ridge
    24' Doughboy AGP
    i just installed one in me pool take a look at my post here wall-mount-skimmer-on-intex-pool-t16418.html .
    just when you do it make sure you put some silicone around the skimmer for very small leaks. found mine on ebay for $11.98 and $12 for shipping. brand new.
    15x4 intex starter pool
    Hayward 1hp pump and filter system
    wall mount skimmer
    BBB maintenance plan
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Well looks like on the hunt for a good deal on a wall mount skimmer unit. Thanks for the reply just what I was looking for.
    1988 Ceder Ridge
    24' Doughboy AGP
    Intex now sells a metal frame pool that INCLUDES a through-the-wall skimmer!
    Just make sure you support it properly like djboy did, so you don't cause undue stress on the liner!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    fordman's Avatar
    Jul 2009
    Iowa
    119
    have any links to the intex pools?
    1988 Ceder Ridge
    24' Doughboy AGP
    http://www.walmart.com/catalog/produ...ct_id=10730729
    I guess it is not Intex brand, and also seems that the skimmer thing is the whole shebang... pump, filter, and all. But it is through the wall...
    ETA: Didn't mean to imply that this pump/filter/skimmer combo is good or adequate, just mentioned that even in the world of 'temporary' pools a through-the-wall setup is being produced.
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Well that skimmer looks big. Don't know how I am going to support it but will do it somehow. And the only down side I will have to take it apart to fold it up for the year.
    1988 Ceder Ridge
    24' Doughboy AGP
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Found the skimmer they use for that pool.
    http://cgi.ebay.com/POOL-SUMMER-ESCAPES ... 286.c0.m14
    1988 Ceder Ridge
    24' Doughboy AGP
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Don't use that skimmer. Buy a skimmer for a normal AG pool like originally planned. If you use the Intex skimmer, you are stuck with the dinky way undersized pump on the bottom.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    fordman's Avatar
    Jul 2009
    Iowa
    119
    I wasn't going to buy it I know it's junk
    1988 Ceder Ridge
    24' Doughboy AGP
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Quote Originally Posted by fordman
    What I ment was the skimmer looked big. I am not going to buy it but the one I buy don't know how I am going to support it have a couple ideas will post pictures next year when I put up my metal frame pool.
    1988 Ceder Ridge
    24' Doughboy AGP
