Thread: DE coming out of returns
    Last night, after manually vacuuming, I backwashed my filter, then turned the the multi port back to filter and I saw what looked like DE coming out of the returns. Is this indicative of a problem with the filter or multi port?
    11000 gal in-ground plaster with spa.
    36 ft2 DE (using Fiberclear)
    Sta-rite 1.5 hp pump
    Sep 2007
    Los Angeles County
    Re: DE coming out of returns
    D.E. out of the return lines indicates you've got something wrong with your grids, manifold, or possibly even that little stem pipe o-ring. Clean off your grids and do a thorough inspection for holes, tears, cracks, etc. Even small holes will cause a problem.
    Semper Fi and Happy Pooling.
    Mar 2007
    Coastalish 'down easter'
    Welcome to TFP!!
    Don't forget the possibility of something being bad in the multiport Also, did you rinse after backwashing? (please refer to this for proper care with a DE filter
    Luv& Luk
