Thread: Ph and high clorine levels
    bwiley47's Avatar
    Princeton, WV
    97
    I understand you should not test your ph during high fc levels (like when shocking), but with a high cya, at what point is it ok to test ph to get an accurate reading?
    If my fc is 7.5 and my ph is 7.6, is my ph accurate?
    16 x 32 AG Fanta Sea 13,500 gal/ Hayward Sand Filter/ 1 hp Hayward Power Flo LX Pump
    1 skimmer 1 main drain
    Re: Ph and high clorine levels
    Yes, your pH is accurate. FC above 10 will mess up the pH results.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    bwiley47's Avatar
    Princeton, WV
    97
    Thanks mermaid queen.
    Didn't want to lower my fc to check ph and take a chance on more algae, now that it is finally gone.
