Results 1 to 11 of 11
Thread: Water Temp questions
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    So with the weather in Dallas in the 100's this week the water temp has been creeping up a couple degrees per day. Last evening I checked and it was 87 . Any adjustments needed when testing Chlorine, ph, alkalinity etc??
    14100 gallon IG Gunite Pool
    Sapphire Smoke Quartz Plaster
    Pentair SunTouch Controller, Intelliflo 4x160 Pump, 520 Cartridge Filter, Intellichlor SWG System
    Legend Platinum Cleaner with booster pump
    My Pool Build
    Jan 2009
    Cupertino, CA
    1,966
    Re: Water Temp questions
    Not really. You always want to test pH before the water has a chance to cool off or warm up much. The only other temperature consideration I'm aware of is for CYA, which doesn't work as well when the water is below 70 or so.
    --paulr
    BBB "Intermediate Swimmer"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Just keep an eye on your chlorine more closely. High water temps, outdoor temps, usually equate to heavier bather load, and usually it means folks leave the cover off to keep the water temp down. So make sure your FC levels are kept up.
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Quote Originally Posted by frustratedpoolmom
    True. Will make sure the FC is up. Have the SWG running 60% for the 8 hours I have the pumps running during the day.
    My Pool Build
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Water temp is up to 90 degrees yesterday.
    We have started looking at shade sails to give a bit more coverage on the pool and this might help. Another thought I had was to dump the ice bucket from the fridge and see what that did.
    My Pool Build
    Loogootee, IN
    122
    Quote Originally Posted by Tonedeaf
    My pool is tiny compared to yours, I started an ice cube collection and filled a 5 gallon bucket and a 1 gallon ice cream bucket up. when the pool was 92 in the middle of the nite I dumped it all in and within 4mins the ice was gone and checked the temp every 30 mins for 3 hours and it didn't change the temp one bit!!! 8)
    18ft x 48in Round Intex Ultra frame. 6,700 gallons.
    jefeyessica's Avatar
    May 2009
    Dallas, TX
    62
    We live north of Dallas, and our pool felt sort of like a bathtub as well. Today we got some thunder storms and rain, which dropped the temperature by at least 10 degrees. Yeah!!
    14,200 gallon in ground Plaster Pool
    "Titan Vertical Grid Filter" -- Pressure DE, 60 sq ft filter area
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Quote Originally Posted by jefeyessica
    Yeah. Got home and with the little bit of rain yesterday the pool temp was down to 85. With it only being forecasted at 92 today, I would think it would stay down at that range. Was a nicer swim last night at 85 than it was the day prior at 90.
    My Pool Build
    Azle Texas
    22
    I feel your pain also I live in Azle and my temp was up to 92. I started running my pool, waterfall at night and made a 10 jet sprinkler that shoots from my spa into the pool also allowing the spa spill over to work. The past three days my temp has lowered to 88, don't feel like taking a bar of soap into the pool now. The weather the end of this week and next week is supposed to be brutal. Ahh welcome to Texas I love it here!
    Azle Texas, 38,000 gal blue gunite Salt water pool with a spill over Spa & 30 foot waterfall.
    Spring Hill, Kansas
    16
    Some friends of mine that used to live in Texas said they used to have an ice company deliver blocks of ice to have them dumped into their pool to cool it off. Not sure of the sizes or quantity. I'm sure 100 pounds or two would help.
    Last year my wife and I bought 20 bags of 7 lbs ice, and dumped them in the pool to try to lower our temp. 5 minutes later, all the ice was gone and nary a drop in temp. Don't waste your money trying this.
    11000 gallon Viking Fiberglass 12 x 28, Intellichlor IC-40 SWG, 24" cascade fountain, 12" cascade fountain, 1 1/2 HP pump, sand filter
    30,403
    The forum has pretty much concluded that ice is very ineffective at reducing your water temperature.
    This works.....a-cheap-pool-cooler-for-the-end-of-summer-t2501.html?hilit=pool cooler
    You can make your own any way you want (connect it to your returns) or you can buy some commercial ones. The evaporative process is surprisingly effective. You will experience very little water loss and your water temp will be affected pretty quickly.
    The higher you shoot the water and the finer you get the drops, the more effective your cooler will be.
