Results 1 to 13 of 13
Thread: Help! Leaks around threads of pump and heater
    Hi, I am setting up all this pool equipment myself for a small aboveground pool and have a problem with steady dripping leaks around the threads from the pump and from the heater. I have wrapped some teflon tape on the plastic connectors that screw into the pump and heater and I've tightened them as much as I can with a wrench and there are still slow steady drips coming out. There don't seem to be any leaks coming from the hoses, which are clamped on tight. Is there a certain method or technique I'm missing that will help me seal up these leaks? Am I supposed to wrap a lot more teflon tape around the threads or add some kind of rubber seal?
    I would greatly appreciate help or advice with this!
    Orlee
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: Help! Leaks around threads of pump and heater
    forget the tape...try some great white ptfe pipe dope
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    is this stuff what you're talking about?
    http://www.lowes.com/lowes/lkn?action=p ... 138-31230D
    Ok, I just hope I can find that or something similar here in Israel!
    I'll post an update. Any other ideas in case it's not available here?
    Orlee
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    that;s it...oops didn't realize you were in israel...good luck
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    so the leak I have at the pvc threads that screw into my pump (that then goes to the filter) can be fixed with this stuff? (not trying to hijack, I think the op is having the same issue)
    30,402
    Yeah, typically teflon tape doesn't seem to work as well on the larger (say over 1") fittings. Properly applied the tape can work on much larger fittings but the thread sealant seems a little more foolproof.
    I really like the neatness of teflon tape but I personally don't use it over 1".
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    so is this something you apply over the existing connection or is it a replumbing deal?
    30,402
    Replumb.
    Take apart the joint and clean any old teflon from it thoroughly, then apply the sealant evenly to the threads.
    Reattach.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    oh, dang. thanks for the info.
    Aug 2007
    near the swamp
    806
    We don't use pipe dope. We use an RTV around the threads in conjunction with thread tape. Always go hand tight only.
    What is an RTV? Thread tape is teflon tape??
    Thanks!
    Gooserider's Avatar
    Feb 2009
    North Billerica, MA, USA, etc.
    211
    RTV is silicone sealant / gasketing type stuff...
    One of the things that I tend to use is "Rector-Seal" pipe dope, same stuff my plumber uses on potable water lines, and black-iron gas and hydronic heating lines. What he does, and says is a very good technique (and I haven't had any leaks on stuff I've done this way) is to put down a layer of dope a couple wraps of teflon tape(make sure you wrap it in the correct direction!) and another layer of dope over the teflon - brush the dope on in the same direction you wrapped the tape...
    The standard directions on the Rector-seal can say 3 turns past hand tight for black iron, I try to get at least two turns and bring the fittings into alignment on the third... It's messy but it works good.
    Gooserider
    Free-form Inground gunnite pool, Estimated 16-17K gallons. New Pentair TR60 ClearPro 24" sand filter and Compupool CPSC-48 SWG, Hayward SP1607X10 Pump w/ 1HP motor, 1.5" plumbing, Polaris Pressure cleaner w/ booster pump. pool is more than 25 yrs old, less than 35. Not painted, deteriorating tile surround. I am paraplegic, get in/out of pool w/ S.R. SMITH PAL portable pool lift (significantly modified)
