Thread: cleaner in with polyquat/elevated chlorine levels
    Mar 2015
    Reading PA
    63
    Good morning,
    Is it safe for my polaris 9500 robot cleaner to do one last run after the polyquat is in? Also - my FC levels are high right now…
    Thank you in advance for your thoughts.
    Thanks!!
    18ft x 36ft 24500 gal vinyl liner inground
    Salt water pool - swim pure plus
    Hayward cartridge filter
    Mod Squad pooldv's Avatar
    DFW, TX
    23,999
    Re: cleaner in with polyquat/elevated chlorine levels
    Your robot will be fine with polyquat and FC up to shock level for your CYA, FC/CYA Chart.
    Mar 2015
    Reading PA
    63
    In it goes - thank you … I just want it as perfect as possible - I had a great open this season because of TFP and I am looking for another one next year.
    Thanks!!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,602
    You're good if within the exceptions pooldv mentioned.
    '70s IG Vinyl 32K gal, Lazy L, Hayward SuperPump 1.5hp 120V, S240 Sand Filter W/DE
    Solar Blanket, Well Water, Borax Added, TF-100 tester. ?° too cold
    1979, 275gal Conway Emerald Spa P-100-2, ES-2 Spa Pack, bromine floater, indoor
    TF-100, Best test kit - TFTestkits.net
