Thread: So Cal check in...
    Oct 2016
    Glendora/Ca
    35
    So Cal check in...
    I've had a pool in my back yard for over thirty years, but...
    I just picked up a Taylor Technologies test kit and have been learning Lots of new stuff!
    It's been fun and confusing. Hoping to learn a bit more.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    24,234
    Re: So Cal check in...
    HI! So glad you found us! Your wallet will be glad also!
    I can't wait for you to get your water balanced using TFP. You just thought your water was clear before! NOW it will look like a jewel
    Kim
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    672
    Put what kind of Taylor test kit you purchased in your signature. They make many different kits. Welcome
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,531
    Welcome to TFP rivermobster
    Have you been having a pool store do your testing in the past ??
    '70s IG Vinyl 32K gal, Lazy L, Hayward SuperPump 1.5hp 120V, S240 Sand Filter W/DE
    Solar Blanket, Well Water, Borax Added, TF-100 tester. June 20-80+
    1979, 275gal Conway Emerald Spa P-100-2, ES-2 Spa Pack, bromine floater, indoor
    TF-100, Best test kit - TFTestkits.net
    Please help keep the lights on so we can be here for others, become a TFP Supporter!
    Oct 2016
    Glendora/Ca
    35
    K2006...
    I've always done my own testing, I've just never been so zealous about it!
    I swap out the water every four - five years, cause I can tell by the amount of chemicals I'm using, it's just not right anymore.
    It's nice to have confirmation of what I suspect, and to be able to dial it in even more.
    Im dealing with the combined chlorine issue right now. I should probably make a new thread....
