Results 1 to 9 of 9
Thread: Adding borates.... 58lbs?!
    Aug 2016
    Dallas, TX
    141
    My pool keeps requiring acid, so I'd like to add borates to buffer the pH. However, pool math says I need 58lbs or borax to go from 0ppm to 50ppm in a 16,000 gallon pool. Is that right?!
    Regarding the rest of the process, I want to lower TA to 60 and then add the borax and required muriatic acid to compensate for the pH rise from the borax?
    Thanks
    16,000 gallons in-ground, raised spa with spill-way, PebbleTec finish. Cartridge Filter M/N CV460, Main Pump; Jandy VSSHP270AUT variable speed ePump, Polaris PB4-60 cleaner pump, Jandy PLC1400 SWG
    I still prefer our boat over the pool
    39,279
    Re: Adding borates.... 58lbs?!
    Yes. And 3.5 gallons of muriatic acid.
    Or use 38 pounds of boric acid which you can get from duda diesel or other places and not need the muriatic acid.
    Saturn94's Avatar
    Mar 2015
    Virginia
    514
    IMO, boric acid is the only way to go. No handling of acid! Just add to the pool and enjoy the benefits.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Aug 2016
    Dallas, TX
    141
    Thanks for the tip on duda; never would have found them on my own!
    Out of curiosity, if my TA is 70, what would happen if I added the boric acid without first lowering the TA to 60?
    39,279
    I do not think anything special would happen. It will just be a little more difficult to lower the TA more if you want/need to.
    Aug 2016
    Dallas, TX
    141
    Do I just dump the dry boric acid in, or do I need to dose it via socks or something?
    Is it best to add 1/2 of what pool math says and sneak up on it? Or just put the 38lbs in and call it a day?
    Thanks!
    JoyfulNoise's Avatar
    May 2015
    13,426
    Add it directly to the pool. You can do it in two batches and brush in between. It will dissolve very rapidly. Let your polaris cleaner roll around too to help mix it up. Keep the pumps running for 24 hours and you'll be all good. As long as 38lbs is what Pool Math tells you is right, you can go ahead and add all of it. Even if you overshoot your borates past 50ppm, it's fine. Some folks target 60ppm because they know they will have a lot of splash out or water loss during the season.
    Matt
    Aug 2016
    Dallas, TX
    141
    Does my pH need to be spot on before I add the boric acid?
    As the boric acid acts as a pH buffer, will future pH adjustments (reduction) require more muriatic acid, and the resultant pH will "last" longer? Or will it require the same amount (or less) of muriatic acid and the result will "last" longer?
    May 2015
    13,426
    Quote Originally Posted by 300winmag View Post
    The boric acid will lower your pH by ~0.2-0.3 units. So just get it close.
    To make pH adjustments after borates are added will require more acid (about twice as much) BUT you should be adding it less frequently so the total amount of acid you use really shouldn't change much.
    Matt
