Thread: pH testing: K-2006 vs Pentair / Poolmaster kits
    Aug 2016
    Dallas, TX
    For the simple test of checking pH, are the red fluids in the Poolmaster and/or Pentair kits interchangeable with the K2006's R-0004?
    16,000 gallons in-ground, raised spa with spill-way, PebbleTec finish. Cartridge Filter M/N CV460, Main Pump; Jandy VSSHP270AUT variable speed ePump, Polaris PB4-60 cleaner pump, Jandy PLC1400 SWG
    I still prefer our boat over the pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    Re: pH testing: K-2006 vs Pentair / Poolmaster kits
    I would say no, although Im not familiar with the Pentair kit. The 2006 kit requires a particular reagent because of its sample size, but its generally not good to interchange reagents with regard to pH tests. Better to wait until you have the proper reagent on hand.
    Essential Links:
    Agree with Patrick. Even different Taylor kits use different pH reagents (because the strength is different for different vial sizes), so I would certainly not mix across brands.
