Thread: Pentair booster pump
    I installed a new Pentair booster pump today. I need to verify what direction the shaft should be turning after installation. As I face the pump the shaft is turning clockwise. Does anyone know if this is correct?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Pentair booster pump
    the impeller is taken off counterclockwise, so clockwise would make sense.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    There's probably a 'rotation' arrow molded onto the back of the pump housing somewhere near the discharge.
