Thread: Running a slide and spa simultaneously
    Jun 2016
    Dallas, TX
    Recently installed a pool with an elevated spa and a slide. Based on current configuration I am unable to operate the slide and spa simultaneously. Is there a fix for this?
    JoyfulNoise's Avatar
    May 2015
    Re: Running a slide and spa simultaneously
    Can you post a picture of your equipment pad? Typically the valves and pipes that control a water feature are on the pool side of the return plumbing. The pool side and spa side return water is usually split using a 3 way valve and you can only direct the return flow either to the pool side or the spa side, not both.
