Thread: Propane and heat pump real world heating costs please?
    Binkoba's Avatar
    May 2014
    Denton MD USA
    2
    Hi
    Will anybody tell me in detail their actual energy costs per month to heat please?
    What size pool?
    Propane Natural or Heat pump?
    What temperature?
    What area?
    Cover?
    Season?
    Monthly cost?
    Thanks
    29000 gallon IG Concrete block pool, Built in 1970
    Swimclear Cartridge Filter C4020, 1 1/2HP Wisperflow Pump
    Hayward Salt Chlorine Generator
    Jun 2012
    western NY
    1,556
    Re: Propane and heat pump real world heating costs please?
    Well, i'll start. I live in Western NY and I run my heater about 10-15 hours/month, May to Sept. I do use a cover Natural gas. At my rates it costs me about $1.00-$1.25/hr to run. I don't maintain any specific temp.
    With this, and the info in my sig line you can see how this won't compare at all to your pool and area. Heating a pool, or anything, is all about the BTU's.
    In the case of my pool, I can raise the water temp by 2 deg/hr with my 100,000 BTU heater. To do the same with yours, you would need a Heater with a BTU output of 480,000 BTU which would be roughly a 575,000 BTU heater (input). At that rating, yours would cost about $6.00/hr to run on my gas rates.
    There are electric conversion tables to use to input the cost and energy usage to heat with heat pumps as well. I don't mess with them as electric heat in my area doesn't make much sense.
    Dan
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    I am investigating heaters as well and found on RayPak's site this application that lets you select your location, pool size, location, months you want to operate, your local costs for gas/propane/electric, pool temp you want to maintain, .. And then shows a comparison chart for these costs. So your energy costs can be a large factor as expected. Of course this is focused on their products, but it is nice for comparison of energy costs.
    I live outside of Atlanta, and my pool water needs no heating from June-September (actually install cooling jets in June-August). Here because of all the AC used, there is a huge electric capacity in the area, so when fall/winter come around electric costs for me drop 47% (from $0.087/kwh to $0.046/kwh). And gas prices increase in the winter. So for me a heat pump is a much better deal in terms of cost of heating.
    However, I use gas heating in my home's main living areas as it heats more quickly and feels warmer from the vents.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Apr 2016
    Quaker Hill, CT
    1,162
    I live in southeastern CT, I've had my pool set at 85 since June. I keep the solar cover on if I'm not using the pool. My heat pump is on a timer and at most will run 10hrs a day when the sun is out and air temps are up. On average my pool as a whole (pump and heater) has added about $75 a month to my electric bill when compared to the previous year when I didn't have a pool. As of yesterday when I looked my pool was still at 85 and the heat pump wasn't running when I got home from work. You can see the specs of my pool and equipment in my sig down below.
    Chuck-
    15x30 Above ground, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is funded by member support click here to help
    Binkoba's Avatar
    May 2014
    Denton MD USA
    2
    Thanks a lot for your help
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    6,425
    First and foremost..........WELCOME TO TFP!!!
    Quote Originally Posted by Binkoba View Post
    Hi
    What size pool?.....
    19x25 approximately 24,000 gallons
    Heat Pump
    What temperature?
    We keep the pool between 84 and 86 depending on the use we estimate
    What area?
    Western Ohio
    Cover?
    A solar blanket is a MUST for any type of heater. If you're not using one you're burning a TON of money for no reason.
    Season?
    We run ours from Early May-Mid October
    Monthly cost?
    In the early and late parts of the swim season the prices increase as the temps are much lower. During this time I would say right around $150 a month. We do tend to keep the temps set lower during this time of the year though as the pool isn't used as much due to the kids being in school. During the warmer Summer months however the bills run about $75-$100. We do have very low power rates in this area which will impact your finial bill.
