Thread: corroded ground wire
    banditig's Avatar
    Sep 2015
    Ohio
    466
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: corroded ground wire
    The actual report is at https://mgtvwncn.files.wordpress.com...unity-pool.pdf
    Rather disturbing. It includes the following: "The motor bonding wire was terminated properly at the motor but had been cut and
    loosely wrapped around the equipment bonding wires"
    This was clearly a bonding issue and the investigators seem clueless.
