Thread: How much water can I drain?
    Aug 2015
    Potomac, MD
    92
    I have an inground plaster pool. Can I drain 2/3 of the water without issue?
    Outdoor concrete pool, 14,000 gallons, Purex Triton Clean & Clear Plus cartridge filter.
    domct203's Avatar
    Jun 2015
    CT
    3,584
    Re: How much water can I drain?
    Where is the groundwater level (water table)? My first concern would be floating/cracking the pool.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Aug 2015
    Potomac, MD
    92
    How do I find out that info?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Are there ponds or creeks around? Is your pool on flat land or on top of a hill?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2015
    Potomac, MD
    92
    No ponds, maybe a small creek about 10 houses down. The house behind me is a lot lower than mine is. Pretty flat in front of my house.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    One way to check is to dig a hole near the pool, as deep as your pool is. See if it fills with water overnight. If so, you may have a problem.
