Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Thread: New Pool on the way.
    After about 1 month of quotes, research and 5 PB and 10 designs later.
    Just signed. New pool and spa hopefully in about 2 month.
    14000K gal of water about 400sq ft of water space
    PB will provide all Pentair equipment.: Pentair Intelliflo VS3050, Pentair Clean and Clear cart filter, Pentair Master Temp heater, Pentair Intellichlor IC40, Pentair Easy Touch 8 aux funtion and wireless control, Pentair wireless remote. Pentair LED intellibrite Pool and Spa light. Pentair Pool shark. Solar Panel Plumbing.
    Water feature: 2 x 24 inch arc sheer and jet on baja step floor connected to 1hp pentair pump. 24" spa spill way.
    Now I have to call and order the fencing contractor, tree removal, and Solar panels and control.
    Excited..
    14000K gal 400sq ft w 6x8 spa, Pentair Intelliflo VS3050, Pentair cart filter, Pentair Master Temp, Pentair Intellichlor IC40, Pentair Easy Touch 8, wireless control. 3x intellibrite LED light. Pentair Kreepy Krauley Sand Shark. Solar Panel Plumbing. 2 x 24 inch arc sheer 24" spa spill way.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: New Pool on the way.
    Sounds nice, don't forget the pics of your progress. The only thing missing from your list is a good test kit (TF100).
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    It will be similar to the CG in shape.
    6'x8' spa
    30' length
    102' perimeter
    Still waiting for permits..
    For some stupid reason the fire dept need a permit and need a pressure check on the nearest fire hydrant. ?!!!!
    The local Water Utility have to do the water pressure test and that will take about week or 2.. ?!!!!
    Arggg.. !!!!
    2 week permit lead time now looks to be going on 5 weeks!
    finally broke ground yesterday.. wow. almost 2 month wait for a fire dept permit. They have to test the nearest fire hidrant for pressure.
    Quote Originally Posted by fkong777
    Why?
    Aug 2008
    Phoenix, AZ
    26
    Quote Originally Posted by Brad S
    Why?
    In case the pool catches fire and they need to put it out.
    15,000 gal Freeform Salt Water (SWG), Pebble Sheen with in floor cleaner. Hayward 1.5hp pump and 425sq ft Hayward Cartridge filter. 35sq ft Waterfall with separate 1.5hp Hayward Pump.
    PB told me that without a Fire Dept permit they have to install a 6" main drain and accessible to the Fire dept near the sidewalk in case they need to use the water for fire. I live in fire zone 4. (I dont know what that really means.)
    Where do you live?
    hacienda heights, CA Basically San Gabriel Valley, Los Angeles County area
    Vero Beach, FL
    462
    I feel your pain. Our PB told us 6-8 weeks to complete everything. However, permitting took longer, inspections have taken longer, etc. There have been more inspections than I thought. They had to check soil compression this week. Plus, my PB uses his own crew for almost everything. He only has 1 guy that does plumbing, 1 that does tile, 1 that does framing, etc., so if the one guy gets sick or takes longer on another pool, we have to wait. UGH. Luckily the contract has an end date that they must be finished by. Although I don't know what we'd do if its not since there was no penalty clause.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Day 0 The $80 that cost me 50K.
    Day 1 Ground Break
    Day 2 finished dig.
    Note: Left side lower edge is the KEY. required pool structure for slopes. It is 18inch deeper and 18 in wide.
    Looks like contruction is going overdrive. I will add pictures later today. Im just going to count working days and not weekends.
    Day 3-off day for subcontractors. No work done.
    Day 4- Rebars for pool structure and concrete cut for plumbling done
    Day 5- Break out cut concrete and dig trench for plumbling.
    My yard is a total mess.
    Day 6- Gas Pipe in, Suction and return piping runs from pool to equip pad. and install pool equipment at pad
    Day 7- in spa piping , in pool piping and equipment piping in.
    Day 8- Electrical.. conduit in
    Day 9 -Electrical to Pool equipment, easy touch panel, connection to main Electrial panel in.
    Getting numerous fence quote at the same time. Fencing is on my own. PB didnt deal with fencing. Probably go with Glass wind blocker fencing. So it wont obstruct my view. City will not let me place fence further down the slope due to 20 ft setback requirement from the Sidewalk..
    updates
    Day 10 & 11 no work done
    Day 12 inspection for rebar and plumbing - passed
    Day 13 Shotcrete and Fence post - took 40 yard of shotcrete - 4 trucks of concrete.
    The pool finally has its shape and structure. Its important to stay home and watch the progress. I had to correct the spa step shaping because the crew had made it off center.. That would totally bug me to have a off center step.
    Aug 2009
    Montgomery, Texas
    33
    Looks nice.
    Really tight fit there. I'm not used to that... We're out in the woods.
    I guess they have to make a mess in order to make it perrrty!!
    54'X26', 9'x7' Spa, Gunite, Pebbletech Blue Granite, Pentair Equipment, 520 Cartridge filt., SWG, 320 chlorinator (just in case), Easy touch 8 control, 2 1/2 hp pool pump, 400k Mastertemp Heater, Polaris 280 on 3/4 hp pump, 22' x 4' Moss rock waterfall, and weaping wall 2.5hp, 10x8 Flagstone island with 3 fountain jets w/ 2.0hp. 28k gallons.
    Aug 2009
    Montgomery, Texas
    33
    Quote Originally Posted by lborne
    Permit? Whats a permit? LOL. I barely remembered to notify the POA that I was doing my pool. Freaking pool builder lives in my neighborhood and he forgot too. Shows you how "cowboy" we are around here.
    Here in suburb, So Cal. Not much space. Try to do major construction without permits will not be wise around here. They will make you rebuild it.
    Pool is still curing after 1 week of shotcrete.
    Aug 2007
    near the swamp
    806
    wow around here most builders get the permit and start building the sameday, finished in 1-2 weeks.
    after a four week break. Coping and waterline tiles are in.
    turtle mosaic
  20. Back To Top    #20
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Questions for OP
    Hi there OP,
    Thanks for posting your photos--things are shaping up!
    What brand of coping and waterline tile did you choose? I like the look, and I'm shopping around for my renovation. On my screen the color of the coping looks to be a pleasant dusty rose or pink--is that so?
    I love your little mozaics. What kind of surface are you going to have installed?
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
