Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Pump leaking from top
    Dec 2015
    Chino/CA
    203
    I noticed tonight my pump is leaking from the top area:
    Is this fixable? I cant tell if the water is coming from the threads, it doesn't looked cracked.
    Chris B.
    New house w/ 28 y/o I.G. 15k gal. pool/spa, Plaster, Hayward DE-480S Micro Clear Filter, Pentair Whisperflo wfe-4, 1HP (Main Pump), Hayward SP2815x20 (Pump for spa jets), Versa Pool Heater, Hayward Pool Vac Ultra, TF-100 Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Pump leaking from top
    Is there a union above that pipe? You can unscrew that nipple from the pump and put Teflon tape and/or pipe dope and reinstall it.
    Dec 2015
    Chino/CA
    203
    No, there isn't:
    I dont know why, but when I checked it tonight the lid was a little loose and my basket is a little discolored, so it seems it ran hot last night or today (pump runs from 12pm-3pm & 12am-5am)
    Is this the type of repair I'm looking at:
    Repairing A Pump Discharge Leak Updated Revised Version - YouTube
    Chris B.
    Yuma AZ
    71
    Exactly as shown in the video. Ensure schedule 80, gray pipe, is used at discharge fitting. Buy a 12" double threaded nipped and cut as described in video. You"ll have a second nipple to use for a later repair.😁
    10,000 gallons IG Freeform, 8ft raised spa,pebble finish
    FNS 60 Sqft DE Filter,2HP Whisperflow for Pool/Spa filtering
    2HP Whisperflow for Spa jets
    1HP Whisperflow for Waterfall
    Master Temp 400,000 Btu Heater
    Dec 2015
    Chino/CA
    203
    Can I get all of these pieces at home depot or pool store?
    Chris B.
    Yuma AZ
    71
    Possibly, I usually get mine at the local nursery supply. Looks like 2" threads from the outlet of your pump. If you follow the video you should be fine.
    Dec 2015
    Chino/CA
    203
    Nursery supply? I would have never thought of that.
    I just called a local pool supply store and he's recommending schedule 40, is that the norm?
    Chris B.
    DFW, TX
    24,450
    Yes, sch 40 is fine.
    Dec 2015
    Chino/CA
    203
    Ok, should I put a union at the pump or just threaded PVC?
    Chris B.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    I would put a union in for future servicing convenience.
    Blows my mind when installers don't put pumps and filters on unions.
    waste of time & resources when you have to cut & replace pipe.
    Dolphin E10 Cleaning Robot.
    Dec 2015
    Chino/CA
    203
    Got it!!
    I'm just curious, is the union a schedule 40 or 80? After the union, what should I use? Just regular sch 40 PVC?
    Is this what I'm looking for:
    Union, 11201-0154 (WhisperFlo Pump - SOLD INDIVIDUALLY) - INYOPools.com
    Chris B.
    DFW, TX
    24,450
    Yes, that will work fine.
    Dec 2015
    Chino/CA
    203
    Is there an o-ring in there?
    Chris B.
    DFW, TX
    24,450
    No, not between the nipple and the pump.
    Yuma AZ
    71
    Ok if you want to use a union, use a hi temp union. The Grey pipe used in video is schedule 80 PVC not schedule 40. Very important to use schedule 80 for pump inlet and outlet to avoid leaks.
    Amazon.com: 2 PACK -CMP Hi-Temp Union 2 Garden
    Dec 2015
    Chino/CA
    203
    Quote Originally Posted by crudsrus View Post
    Sent from my C6730 using Tapatalk
    Nice!!! I just picked up that same exact union.
    Is this cement good? Do I need primer?
    Or should I have went with the red:
    Christys 8 fl. oz. PVC Pipe Cement-RH-RHBV-HP - The Home Depot
    Chris B.
    Dec 2015
    Chino/CA
    203
    Any differences in the cement?
    Chris B.
    Aug 2016
    Georgia
    49
    The wet or dry is fine. I wouldn't glue anything without using cleaner though.
    Dec 2015
    Chino/CA
    203
    Cleaner? Never heard of that. None of the videos I watched never mentioned it.
    I just finished measuring and cutting everything, should I put lube on the o-ring for the union?
    Chris B.
  20. Back To Top    #20
    DFW, TX
    24,450
    The blue wet/dry cement is good. Need a primer, like purple, to clean the pvc first. Yes, lube the o-ring with plumber's silicone lube/grease.
