Thread: bromine in pool
    Mar 2012
    Lebanon,Tn
    47
    bromine in pool
    Hey, My SWG went out so the next few months i am going to be useing bleach. BUT I have access to 50 pounds of bromine tabs will it be alright to use them in my pool, they are FREE.
    21x42 olympic sports pool
    18000 gal
    Intelliflo vs pump
    Pentair ic40 SWG
    Suntouch control
    TR100 Pentair sand filter
    Letro ledgen II pool cleaner
    Vinyl liner
    TF Test Kit's TF100
    Donldson's Avatar
    NW Ohio
    2,917
    Re: bromine in pool
    Do you want to permanently convert your pool to bromine?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: bromine in pool
    Bromine is like herpes once you have it you always have it, except in the case of a pool it is possible to get rid of it with a total water replacement.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: bromine in pool
    Quote Originally Posted by Isaac-1 View Post
    That's one way to put it!
    Isolated Spa - 345 Gallons
