Results 1 to 12 of 12
Thread: Where do you buy washing soda AKA soda ash?
    Aug 2016
    Merrimack, NH
    26
    Red face Where do you buy washing soda AKA soda ash?
    I think my local store is out of Arm & Hammer Washing Soda.
    Does anyone buy online? If so, what are you buying?
    Thank you for the help!
    13,600 gallon (round, 24' diameter, 4' deep), above ground, Pentair OptiFlo 1.5 HP 2S pump, Pentair EasyClean ECDE90 filter, TF-100
    Aug 2016
    Wilmington/NC
    115
    Re: Where do you buy washing soda AKA soda ash?
    I picked mine up at walmart
    Little ole baby pool. 14' x 42" Pro Series 3300G pool. AG Vinyl with metal frame. Currently installed are a Intex pump/sand filter SF60110 3000GPH and Intex SWG ECO8110. Filled with city water. TF100 Test kit.
    Aug 2016
    Wilmington/NC
    115
    Aug 2015
    Grandy, NC
    135
    Raising pH? Use Borax (white box says Borax), not washing soda Wallyworld, ace hardware, any grocery store
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    49
    Same here. Wal-mart, Arm & Hammer washing soda in the laundry detergent isle.
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Walmart usually has it. If not you can buy anything online.
    chiefwej
    Aug 2015
    Grandy, NC
    135
    From Pool School this site: Raising PH
    PH can be raised in three ways: borax, soda ash, and aeration. Borax is usually the best choice. Borax raises the PH and also raises the TA level just a little. If your TA level is low soda ash will raise both the PH and TA levels.
    30,431
    Good post, kschmidt1. Borax has always been the best. Washing soda has a residual (can't remember what it is) that while it is small, simply isn't needed in your pool. Borax leaves no residual.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    wait, isn't that backwards? Shouldn't it be:
    Borax raises ph without raising TA (the reason why it's often recommended over Soda Ash)
    Soda ash raises ph and also raises TA a bit.
    Matt (JoyfulNoise) pointed this out to me awhile back.
    Dolphin E10 Cleaning Robot.
    Aug 2016
    Merrimack, NH
    26
    Cool I'm going to check the nearest Walmart.
    I am trying to raise pH and TA currently.
    Aug 2016
    Wilmington/NC
    115
    Quote Originally Posted by zapados View Post
    It's generally in a random spot in the laundry isle. Took me a while to find it's as well. I use/d it because I was trying to raise both as well.
    Plus don't you have to test for borates when using borax? Just asking for my benefit and who ever else wants to know.
    Good to know on the residue with ash.
    May 2012
    Montville NJ
    545
    Quote Originally Posted by Super B View Post
    Borax will raise borates - but you need a LOT of borax. more than you will be adding just to adjust your pH. Borates are not a bad thing. I have been trying to add them to my pool - sometimes I add borax and coutner with acid. Other times my pH drops and I just raise it with borax. I am only around 40 ppm on Boarates after 2 seasons of adding borax.
    In my grocery store the washing soda is right next to the boarx - but both are over by the clothes dye - not by detergents or bleach.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
