Thread: Question about rust
    Sep 2015
    Los Angeles
    31
    Question about rust
    I have a spillover made of stainless steel that is getting spots of rust. I'm concerned about getting corrosive/unhealthy chemicals into the spa while cleaning it. What is the safest/best way to clean it?
    Thanks!
    1100 gallon gunite IG spa with vanishing edge and 300 gallon overflow basin. Cartridge filter, hayward variable speed pump, finished 11/15/15, Taylor kit,
    Apr 2013
    Sacramento, CA
    2,769
    Re: Question about rust
    Very fine 600 sand paper
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    357
    Stainless shouldn't rust. If it is actually rusting itself, then the alloy is incorrect for the installation or the passivation layer has been damaged. Rust spots will appear on stainless due to contact with carbon steel. Polishing with wet or dry corundum sandpaper will remove it, but it can also remove the passivation layer that protects it. Which may be why you are seeing rust spots.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
