Results 1 to 8 of 8
Thread: Dummy is back
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Dummy is back
    Could someone post a brief discription on how to do quotes I'm a pretty quick learn
    Thanks
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Dummy is back
    Quote Originally Posted by orthofish
    Thanks
    You click on the "quote" button in the top right hand of the post. It'll come back with a "post a reply" box with the quoted text at the top, and you just type in below it.
    Edit: you can also edit your posts by clicking on the "edit" button, too. I edited this to add " and hush, you're not a dummy! ".
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Dummy is back
    And if you want to put something other than an existing post into a quote box, you do so with the following:
    Code:
    This┬*is┬*in┬*the┬*quote┬*box.
    which produces the following:
    This is in the quote box.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Dummy is back
    Quote Originally Posted by MikeInTN
    I'm not sure I've got it. Gonna try
    Thanks
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Dummy is back
    O.K. I might live in the country but I'm educated. I click the quote button located in the reply I'm trying to quote or the quote button above where I'm typing at this very moment
    Lynn
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Dummy is back
    You click the quote button in the post that you're replying to. So, if you were going to quote this post of mine, you'd click on the quote button up and to the right of this message.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Dummy is back
    Thanks Mike. I believe I've got it
    Lynn
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Dummy is back
    Ennytime!
    Intex 8110 SWCG
    "Fear the Schnauz!"
