Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: New Owner/Builder Pool - NorCal
    Apr 2016
    Brentwood, CA
    25
    We are starting a new pool this fall/winter. Pool designer has been working the drawings for several weeks, but almost complete. My wife and I are going with the lagoon effect and want the pool to feel natural. The design is ~715 sf, ~160 perimeter feet, ~18,000 gal. Hope to pull permits in September. Any feedback is appreciated.
    Apr 2016
    Brentwood, CA
    25
    Re: New Owner/Builder Pool - NorCal
    Plan view
    Jan 2016
    Mesa, Az
    541
    That looks beautiful, but I'd put a raised spa in where that landscape island is now outside the door or the one behind the rocks outside your sunshelf.
    Sep 2015
    Tucson, Arizona
    86
    Very cool design. With that surface area but only 18,000 gallons, do you not have a deep end? Your design has a lot of enticing rocks to jump from and plenty of space, so I'd make sure there was a deep end somewhere. I would also want to make sure there was plenty of above-water lighting to illuminate the rocks and plants, and have those lights build into the design.
    Owner Build. 32x16, with 6x8 raised spa. Broke ground April 1, 2016, swimming July 18. Pentair Intelliflo VS + Whisperflo for Water features; Clean & Clear Filter 420; Master Temp Heater 400k BTU; Intellibrite 120V pool and spa lights; Regular ol' plaster.
    Feb 2016
    Atlanta, GA
    145
    Looks great.
    Maybe add some fire features or tiki torches to complete the look.
    I look forward to watching your build.
    Apr 2016
    Brentwood, CA
    25
    Great idea on the spa location. We have decided to use solar heat and natural gas heater to maintain temps to keep entire pool warm like a spa, but no plans to add spa at this point.
    The pool depth ranges from 3.5' to 5.5'. I have been hesitant about a deep end.
    As for fire features I plan on designing my landscape for future additions (pipe sleeves, etc.), but no longer in the budget for this go around. I have a 31" fire pit that is feed off a 800,000 btu gas meter that shoots fire higher than my fence, I hope this will satisfy be fire needs until funding becomes available for tiki torches or other features.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    Can you take and share a picture of where the pool will be going?
    That is an AWESOME design.
    Are the stand alone arrows where the returns will be? Do I see a skimmer in the cove?
    It looks like you have it covered with the lights!
    Apr 2016
    fontana, CA
    92
    Wow! This is going to be gorgeous! I can't wait to follow this build.
    Fontana, CA, started 7/26 completed 8/31, IG pool/spa/slide/waterfall/grotto 17,000 gallons, pentair quad 100, pentair mastertemp 400,000 BTU, Intelliflo VS 3HP, Easytouch 8 w/ IC40, screenlogic 2, 2 5g color LED pool lights, 5g color LED spa light, TF-100
    Apr 2016
    Brentwood, CA
    25
    This is the proposed location for our pool.
    Jul 2012
    Tallahassee, FL
    30,535
    The pool will be the cherry on top in that awesome backyard. I bet you are going to cry with the all of that pretty grass goes bye-bye
    Apr 2016
    Brentwood, CA
    25
    Our pool design is 98% complete, just cleaning up a few details on the drawings. Before I send it to the structural engineer, I would appreciate any other suggestions/feedback from owners or builders in regards to this design.
    - Niche vs. nicheless lights?
    - Circulation on large shelf?
    - Pool depth too shallow?
    - Auto fill?
    - Recommended rock that can withstand sitting in water?
    - etc.
    Thank you again
    Let me know if you have trouble viewing the design. I am Not sure how to get images to open to display in higher quality. Any ideas?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    I'll add two comments, but first - awesome plan! I love it.
    With any young kids in the pool, yours or others, there appears to be a significant blind spot for lifeguarding in the rock nook. If that visibility issue it correct, I'd have a tough time recommending the design - though fantastic.
    On the niche vs nicheless, the nicheless are obviously smaller and therefore more nimble from a design and function standpoint, and you need more of them. Consequently, you are introducing more potential points of failure. They are also a newer product. The full-size LED lights are brighter, just as beautiful from a color perspective, you need fewer, etc. Regardless, with a pool of your sophistication, make sure you get the equipment required to allow you to take full advantage of the lights. By that I mean beyond selecting colors and shows, but control over dimming, motion shows and custom shows. With Hayward that means in addition to the automation system, one needs to add a ColorLogic Network Module. It's only a few hundred but not something to miss on your pool. All that said on lights, with the nicheless, since you'd have more, would look even better with the motion effect working (I.e. like running Christmas lights).
    Best of luck with your build.
    Be sure to stock up on plenty of POP (pool owner patience) for the process.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2016
    Brentwood, CA
    25
    Thanks for the feedback. I think I will be adding 1-2 cameras onto my camera system to cover this area. Hopefully that is sufficient to address the concern.
    Do the hayward lights integrate with the Pentair automation system?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,746
    Pentair automation can control the Hayward's but it will be clumsy and light shows and colors won't coincide with what the automation is telling them to do. Have you looked into the Pentair Globrites?
    With automation, you really have to stick to one brand for evening except filters and heaters.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Apr 2016
    Brentwood, CA
    25
    Getting ready for the big dig. Permit was submitted 2 weeks ago and we removed existing trees, grass, and started grading. Hard to turn back now.
    Dos anyone have contacts for rock work?
    Jul 2016
    Pleasanton, CA
    8
    Congrats - looks like a great start.
    Are you using a contractor or doing the owner builder route?
    Apr 2016
    Brentwood, CA
    25
    Owner builder.
    Jul 2016
    Pleasanton, CA
    8
    I'm super excited to see how your pool turns out. I'll be doing the same thing in a few short months. Still working on getting my retaining wall built.
    Jul 2012
    Tallahassee, FL
    30,535
    Bye-bye grass and trees. That is a LOT of work up front but will be worth is when everything is done. Too bad you did not have the pool to jump into to cool off after that hard work
    Kim
  20. Back To Top    #20
    Apr 2016
    Brentwood, CA
    25
    Excavation started yesterday and plan to be back to finish tomorrow. Finally underway after talking and planning for 7 months.
