Thread: pool coping and deck gap
    Jun 2016
    sacramento ca
    1
    I have a 90 foot perimeter on in ground pool with white coping, a concrete deck 4 foot wide the gap is appx 2 inch the filler is removed.
    I know the gap is to big.
    the question I have is when I look straight down on the gap I see about 1/2 in to 1 inch of top of pool wall that the coping does not cover,is the coping installed correctly?
    if i pour new concrete should the new concrete sit on any part of wall with spacer in between or should coping extend out over the wall so no concrete can touch wall.
    I am just trying to mainly close gap to 1/2 in between deck and coping and looking for best way. I do plan to do an overlay on deck as concrete is stable.
    I thought about cutting concrete back say a foot and repouring closer to coping as I am not sure what will stick to side of current deck
    Thanks in advance
    kidney shape pool 20000 gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: pool coping and deck gap
    Welcome to TFP!
    Yes, that is normal, the deck sits on the pool edge a little and the sealer in between.
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by larry2972 View Post
    Thanks in advance
    whatever you do please make sure deck does not bind to pool wall- when either of them start to move due to thermo expansion/contraction they need a way to do this independently or one of them will crack, most likely the pool wall.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
