Thread: do I need a separate booster pump?
    Sep 2015
    Austin
    137
    Hi All,
    my current pump set up is that I have a single speed motor for main filtration and a booster pump to use for the polaris cleaner. I'd really like to switch to a VS pump and my question is do I still need to use a booster pump or can I have that running from the VS pump?
    thanks!
    26,390 gallons IG, Centex plaster, Hayward DE 4820 filter, Century Centurion B2859 pool pump motor.
    Booster pump for polaris 280
    Spa
    Built 1997
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,493
    Re: do I need a separate booster pump?
    I believe that you will still need the booster pump, as it is designed to run your cleaner.
    I 'assume' you want a VS pump to save on your energy bill. If so, your best bet would be to buy the VS pump and a Robot cleaner which needs no booster pump.
    Sep 2015
    Austin
    137
    Quote Originally Posted by Jimrahbe View Post
    Yes, I was hoping to save on my energy bill. However, since the polaris runs for only 1 hour a day, it doesn't make sense to buy a new robot cleaner until the polaris gives in. Isn't it possible to run the VS pump for the polaris as well? I thought the point of the VS pumps was that you could vary the rpm to meet the separate needs of the spa/pool/cleaner?
    Thank you for your reply.
    Spa
    Built 1997
    Apr 2015
    tucson, arizona
    1,120
    The booster pump provides specific pressure at a specific head to run these cleaners, the VS pumps are for controlling main Pool & Spa pump
    Apr 2013
    Sacramento, CA
    2,769
    Polaris makes specific models for use with a vs pump. If you don't have one of those(see my sig) you will not have a good experience.
    Sep 2015
    Austin
    137
    Quote Originally Posted by gwegan View Post
    Thank you gwegan.
    I am beginning to think that I will wait until my current single speed gives up before even replacing that. I am running my pump for 4 hours a day and I should go out with my multimeter to figure out how much that is costing me but I suspect not enough to justify replacing it before it gives up. Same with the polaris.
    thank you all for your great replies.
    Spa
    Built 1997
